time() drifting more than expected
06/08/2009 10:47 AM
post31090
Hi:
I notice that the time reported by time() drifts by about 8 seconds on the hour. The hardware is a PPC405 processor
running QNX 6.3.2 and there is no RTC.
Questions:
1) Is this a normal amount of drift? Seems kind of high to me.
2) What drives the 'ticking' of this OS clock? I'm assuming it's tied to some periodic interrupt from a hardware timer.
3) Anyone have some suggestions (algorithms) for reducing the amount of this drift locally? NOTE: I cannot use NTP to
synchronize the clock. Instead we have another 'controller' card (with an RTC) that sets the time at bootup and then
resyncs the time every hour. I could increase the frequency of these updates but was wondering if there was something I
could do locally.
thanks
robert
RE: time() drifting more than expected
06/08/2009 10:55 AM
post31097
Could it be that the time between the timer interrupt ( I'm assuming that is what keeping the system time on PPC), is
not exactly what the system think it is? For example it's support to be trigger at every 1ms, but instead it's every .
998 ms.
> From: Robert D'Attilio [mailto:community-noreply@qnx.com]
> Sent: June-08-09 10:48 AM
> To: ostech-core_os
> Subject: time() drifting more than expected
> Hi:
> the hour. The hardware is a PPC405 processor running QNX 6.3.2 and
> there is no RTC.
> Questions:
> this drift locally? NOTE: I cannot use NTP to synchronize the clock.
> time at bootup and then resyncs the time every hour. I could increase
> I could do locally.
> thanks
> robert
> http://community.qnx.com/sf/go/post31090
Re: time() drifting more than expected
06/08/2009 11:18 AM
post31101
Hi Robert.
1) I'd say that's more drift than you should expect.
2) That's correct - the OS clock is maintained by adding a number of ns based each time a periodic tick interrupt
arrives. Most of the interesting parameters live on the system page in the qtime section - take a poke at http://www.
qnx.com/developers/docs/6.4.1/neutrino/building/startup.html#qtime for more details. With regards to your drift problem
, chances are either (A) some ISR is taking more than a full tick to complete on a regular basis, causing hardware clock
ticks to get lost; or (B) the kernel clock parameters are not set correctly for your board.
In the case of (A) a kernel event trace might be informative - since it uses the CPU cycle counter as its timebase
instead of the clock tick, it's handy for diagnosing this kind of thing.
3) All other things being equal I'd suggest writing a "reference clock" driver for your board to plug in to NTP. ;) It
might be a little more complicated to get started - I found the documentation rather lacking - but it leverages all the
experience that's gone in to the NTP clock disciplining algorithm. Unfortunately, correcting for clock frequency error
is not easy to do in QNX; you can either (a) have a thread that keeps periodically calling ClockAdjust() to maintain the
drift correction, or (b) remap the system page RW and scribble new values directly into kernel memory. As far clock
discipline algorithms go, though, if you really want to code it yourself a simple PI controller is probably good enough
- though some despiking to eliminate outliers can be helpful if your clock source can occasionally have variable
latencies.
-Will
06/08/2009 3:53 PM
post31159
8 seconds is defninitely too much.
If it's case case B, it might be able to check the startup to see how to set this, what BSP is this?
06/10/2009 10:51 AM
post31350
Will:
Thanks for the information. I dumped the qtime settings once the card
was running and saw the following:
cycles_per_sec: 200,000,000
nsec_inc: 1,000,000
timer_rate: 5
timer_scale: -9
adjust.tick_nsec_inc: 0
adjust.tick_count: 0
So it appears to be configured correctly with interrupts occurring every
1 ms and adding 1,000,000 nsec to the time counter every interrupt.
So I started up the profiler and grabbed a 3 second profile. I see that
the time between interrupts (time between successive "Entry" events)
varies anywhere between 1005 - 1019 microseconds. I would roughly
calculated an average of 1010 ms between the timer interrupts. Even with
the CPU idle i.e. no other competing threads/processes running between
successive timer interrupts, interrupts still are occurring every 1005
microseconds apart. Working backwards from an observed drift of 8
seconds/hour should give 2 microseconds/millisecond drift. So I'm a bit
puzzled by the larger values I'm measuring - on further thought I'm
wondering if the extra 3 to 13 microseconds are due to the overhead of
the instrumented kernel and the profiling?
I might try now to use ClockAdjust() to apply a 2 microsecond offset on
every interrupt (tick) to see if that will help.
A couple of points though:
1) I didn't see any events labeled the equivalent of "IntLock() or
IntUnlock()" in the trace log. What are the QNX equivalents and does
anyone know if they can be logged by the profiler?
thanks
From: Will Miles [mailto:community-noreply@qnx.com]
Sent: Monday, June 08, 2009 11:19 AM
To: ostech-core_os
Subject: Re: time() drifting more than expected
Hi Robert.
based each time a periodic tick interrupt arrives. Most of the
take a poke at
http://www.qnx.com/developers/docs/6.4.1/neutrino/building/startup.html#
qtime for more details. With regards to your drift problem, chances are
regular basis, causing hardware clock ticks to get lost; or (B) the
uses the CPU cycle counter as its timebase instead of the clock tick,
driver for your board to plug in to NTP. ;) It might be a little more
but it leverages all the experience that's gone in to the NTP clock
error is not easy to do in QNX; you can either (a) have a thread that
keeps periodically calling ClockAdjust() to maintain the drift
directly into kernel memory. As far clock discipline algorithms go,
probably good enough - though some despiking to eliminate outliers can
latencies.
-Will
OSTech
http://community.qnx.com/sf/go/post31101
06/10/2009 11:08 AM
post31354
I don't know if it helps any, but it used to be the case that there
could be a lot of variation in individual crystal oscillators (at one
time +/- 5 percent wasn't unusual). Is the magnitude of the problem the
same on all boards of this type? Or is this particular piece of
hardware an outlier?
On Wed, 2009-06-10 at 10:51 -0400, Robert D'Attilio wrote:
> Will:
> nsec_inc: 1,000,000
> timer_rate: 5
> timer_scale: -9
> thanks
> To: ostech-core_os
> Hi Robert.
> take a poke at
> probably good...
06/10/2009 11:21 AM
post31359
So far I've only been able to profile two boards and they both show the
same drift. The crystals we use are rated at 100 ppm which works out to
8 seconds a day. I'm seeing a drift about 24 X larger than that.
From: Neil Schellenberger [mailto:community-noreply@qnx.com]
Sent: Wednesday, June 10, 2009 11:08 AM
To: ostech-core_os
Subject: RE: time() drifting more than expected
> Will:
> nsec_inc: 1,000,000
> timer_rate: 5
> timer_scale: -9
every
that
with
bit
on
> thanks
> To: ostech-core_os
> Hi Robert.
ns
> take a poke at
are
it
clock"
> disciplining algorithm. ...
06/10/2009 11:24 AM
post31362
Oh well, another long shot shot to heck.... ;-)
> To: ostech-core_os
> > Will:
> > nsec_inc: 1,000,000
> > timer_rate: 5
> > timer_scale: -9
> every
> that
> with
> bit
> on
> > thanks
> > To: ostech-core_os
> > Hi Robert.
> ns
> > take a poke at
> are
> > In the case of...
06/10/2009 11:34 AM
post31368
Neil, any idea what the published latency is on servicing interrupts in
QNX? Does 2 microseconds sound about right?
Sent: Wednesday, June 10, 2009 11:24 AM
To: ostech-core_os
the
to
> To: ostech-core_os
the
> > Will:
card
> > nsec_inc: 1,000,000
> > timer_rate: 5
> > timer_scale: -9
> every
> that
> with
between
1005
> bit
of
> on
> > thanks
> > To: ostech-core_os
> > Hi Robert.
> ns
> > take a poke at
> > qtime for more...
06/11/2009 10:28 AM
post31492
Hi Robert,
Sorry for the delay on this: I've been trying to find a definitive
answer for you. So far the best I've come up with is that we don't have
any "official" published latency numbers. The variation between
different boards makes that a bit tricky.
When you ask specifically about 2us, do you mean the interval between
interrupt service start and EOI? Or do you have in mind time between
interrupt raise and service start? Or something else?
Neil
> To: ostech-core_os
> the
> to
> > To: ostech-core_os
> the
> > > Will:
> card
> > > nsec_inc: 1,000,000
> > > timer_rate: 5
> > > timer_scale: -9
> > every
> > that
> > with
> between
> 1005
> > bit
> of
> > on
> > > IntUnlock()" in the trace log. What are the QNX...
06/11/2009 11:40 AM
post31498
Neil no worries.
I'm looking at the time between interrupt raised by the device and the
time OS recoginizes and starts to service it.
Don't kill yourself trying to find it or worse measure it :)
robert
Sent: Thursday, June 11, 2009 10:28 AM
To: ostech-core_os
Hi Robert,
Neil
in
> To: ostech-core_os
> the
> to
> > To: ostech-core_os
one
> the
> > > Will:
> card
> > > nsec_inc: 1,000,000
> > > timer_rate: 5
> > > timer_scale: -9
> > every
interrupt.
> > that
events)
Even
> > with
> between
> 1005
a
> > bit
I'm
overhead
> of
> > > the instrumented...
06/11/2009 11:42 AM
post31500
If the latency is stable time wise it shouldn`t be an issue. I mean the latency could be half a ms and it should not
affect the precision of time.
Sent: June 11, 2009 11:41 AM
To: ostech-core_os
Neil no worries.
robert
To: ostech-core_os
Hi Robert,
Neil
in
> To: ostech-core_os
> the
> to
> > To: ostech-core_os
one
> the
> > > Will:
> card
> > > nsec_inc: 1,000,000
> > > timer_rate: 5
> > > timer_scale: -9
> > every
interrupt.
> > that
events)
Even
> > with
> between
> 1005
> > > microseconds apart. Working backwards from...
06/11/2009 1:03 PM
post31518
You're right now that I think about it...thanks
Sent: Thursday, June 11, 2009 11:43 AM
To: ostech-core_os
latency could be half a ms and it should not affect the precision of
time.
To: ostech-core_os
Neil no worries.
robert
To: ostech-core_os
Hi Robert,
Neil
in
> To: ostech-core_os
> the
> to
> > To: ostech-core_os
one
> the
> > > Will:
> card
> > > nsec_inc: 1,000,000
> > > timer_rate: 5
> > > timer_scale: -9
> > every
interrupt.
> > that
events)
Even
06/10/2009 4:41 PM
post31431
Can't seem to get ClockAdjust() to adjust the time!
Here is how I am calling it:
struct _clockadjust adjustment;
adjustment.tick_nsec_inc = 2000;
adjustment.tick_count = 0;
ClockAdjust( CLOCK_REALTIME, &adjustment, NULL);
My understanding is that setting tick_count=0 will apply the
(tick_nsec_inc) offset on every tick. Is my interpretation correct?
I would also like to try the alternative of modifying the nsec_inc qtime
entry directly. There is some mention of getting the physical address of
the qtime sys entry and then using mmap to remap it r/w. Would someone
have a code snippet of this as I'm not 100% sure how to do it.
Thanks again
Robert
To: ostech-core_os
the
to
> To: ostech-core_os
the
> > Will:
card
> > nsec_inc: 1,000,000
> > timer_rate: 5
> > timer_scale: -9
> every
> that
> with
between
1005
> bit
of
> on
> > thanks
> > To:...
06/10/2009 4:44 PM
post31432
Setting tick_count to zero will mean no changes are done...
> Thanks again
> Robert
> To: ostech-core_os
> the
> to
>> To: ostech-core_os
> the
>>> Will:
> card
>>> nsec_inc: 1,000,000
>>> timer_rate: 5
>>> timer_scale: -9
>> every
>> that
>> with
> between
> 1005
>> bit
> of
>> on
>>> 1) I didn't see any...
06/10/2009 4:59 PM
post31436
Colin:
Quoting from the documentation
(http://www.qnx.co.il/developers/docs/6.3.0SP3/neutrino/building/startup
.html?printable=1) in the syspage_entry qtime section:
...You could give ClockAdjust() a value of 0 for the number of ticks, to
indicate that you want to make this adjustment "permanent". If you don't
want to do that, you can give the ClockAdjust() function the maximum
possible value for tick_count...
I would interpret the first sentence to mean that adjustment will always
be applied. If that isn't correct then maybe the docs should get fixed
or at least some clarification added.
From: Colin Burgess [mailto:community-noreply@qnx.com]
Sent: Wednesday, June 10, 2009 4:45 PM
To: ostech-core_os
qtime
of
> Thanks again
> Robert
> To: ostech-core_os
> the
> to
>> To: ostech-core_os
> the
>>> Will:
> card
>>> nsec_inc: 1,000,000
>>> timer_rate: 5
>>> timer_scale: -9
>> every
>> that
>> with
>>> the CPU idle i.e. no other...
06/11/2009 9:27 AM
post31476
I think those docs are wrong - as per the ClockAdjust() manual page...
http://www.qnx.com/developers/docs/6.4.1/neutrino/lib_ref/c/clockadjust.html
"You can cancel any adjustment in progress by setting tick_count and tick_nsec_inc to 0."
and from the code (services/system/ker/nano_clock.c)
if(qtp->adjust.tick_count) {
// Adjust the clock
qtp->nsec_tod_adjust += qtp->adjust.tick_nsec_inc;
// If an adjustment to the clock is over we restore orig nsec_inc.
if(--qtp->adjust.tick_count == 0) {
qtp->adjust.tick_nsec_inc = 0;
MEM_BARRIER_WR();
> Colin:
> To: ostech-core_os
> qtime
> of
>> Thanks again
>> Robert
>> To: ostech-core_os
>> the
>> to
>>> To: ostech-core_os
>> the
>>> On Wed,...
06/11/2009 9:50 AM
post31485
Colin:
Thanks for the clarification.
robert
Sent: Thursday, June 11, 2009 9:27 AM
To: ostech-core_os
html
// Adjust the clock
nsec_inc.
MEM_BARRIER_WR();
> Colin:
to
don't
always
> To: ostech-core_os
> qtime
> of
someone
>> Thanks again
>> Robert
>> To: ostech-core_os
>> the
>> to
>>> To: ostech-core_os
>>> could be a lot of variation in individual crystal oscillators...
06/11/2009 9:53 AM
post31486
That whole section in Building Embedded Systems on adjusting the clock
looks a bit dubious to me. I'll create a doc PR and try to track down
the original information (from one of the defunct newsgroups). Thanks
for pointing this out.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
06/11/2009 10:20 AM
post31489
Thanks Steve. This paragraph, in the same section, could also stand a
bit of clarification and beefing up with a code example:
"...If you need to change the number of nsecs that the OS adds to the
time when a tick fires, you can manually adjust the nsec_inc value in
SYSPAGE_ENTRY (qtime).
What you'll need to do is find out the physical address of the syspage.
If it's already in nsec_inc you won't need to modify startup. If not,
modify startup to put it there. Then use the mmap_device_memory()
function to make the physical address of the syspage writable. That is,
get the offset to the read-only page, and map a new block of memory to
the address...."
Would it be possible to get some kind of notification when it gets
updated?
robert
From: Steve Reid [mailto:community-noreply@qnx.com]
Sent: Thursday, June 11, 2009 9:54 AM
To: ostech-core_os
Technical Editor
OSTech
http://community.qnx.com/sf/go/post31486
Re: RE: time() drifting more than expected
07/08/2009 5:38 PM
post33440
Hi, Robert.
I discussed this section with Colin and Brian, and they thought it would be best to remove the dubious part of it
completely, and instead recommend using the startup code to adjust the timing. The change will be in the next release.
> the address...."
> updated?
> robert
RE: RE: time() drifting more than expected
07/10/2009 10:40 AM
post33535
Thanks for the update Steve.
robert
Sent: Wednesday, July 08, 2009 5:39 PM
To: ostech-core_os
Subject: Re: RE: time() drifting more than expected
Hi, Robert.
be best to remove the dubious part of it completely, and instead
syspage.
is,
> the address...."
> updated?
> robert
OSTech
http://community.qnx.com/sf/go/post33440
Re: time() drifting more than expected (New Info)
09/11/2009 10:39 AM
post37803
Hi:
I'm back again with some new info on this problem were experiencing. But to recap: we're running QNX632 on a PPC405EP
clocked at 200 MHz. We're noticing a time drift (loss) of 71 seconds over a 12 hour period. The card does not have an
RTC. All time deltas I'm reporting are relative to an NTP synchronized clock.
I've conducted a few more tests in the hope of isolating the root cause and he is a summary of my results (please bear
with the length :
1) The oscillator driving the CPU is a 25 MHz part rated at 100 ppm. We measured the oscillator with the spectrum
analyzer and found it to be 25.0001 MHz. So it's within spec. The 200 MHz output from the internal PLL is not accessible
but we were able to measure it indirectly and confirm it was centered on 199.985 MHz.
2) Time drift varies with the load on the CPU. With just the bare OS running (with serial driver for comms) I've
measured a loss of -49 seconds over 12 hours. As processes are added back, this loss increases to the -71 seconds where
the full application load is running. The first thing that comes to mind in explaining this is that some application(s)
are locking out interrupts but see point 3) below which proves this isn't the case.
3) I configured my own version of a time-of day clock by routing an external periodic signal (running at 100 ms period,
or 1 ms period) to an external interrupt and counting the number of ticks in my interrupt handler. The ticks were
initially synchronized with the same value in the OS-based clock (i.e. what's returned by a call to time()). Over a 12
hour period my clock showed a 0 sec loss/gain versus 50 seconds for the OS clock. Note this measurement was made with
just the bare OS, no application code other than my interrupt handler. This indicates, to me, that the time loss in the
OS clock is not because of locked out interrrupts, otherwise my interrupt-based clock would show similar losses.
4) Changing the tick rate on the OS from 1 ms to 10 ms improves the loss by a factor of 10x i.e. loss goes from -49
seconds to -5 over 12 hours.
I think the above strongly suggests that there is something not quite right in the maintenance of the OS-based clock. I
do expect some losses due to the accumulation of errors due to interrupt latency in processing the decrementer interrupt
but the anomalies I'm seeing are much larger than I (and others) expect. I do have a temporary workaround by "playing"
with the value intput into the decrementer in the BSP startup code. However, I would have to tune this value with every
release of our software as the drift varies with the CPU load.
Can someone (at QNX) take another look at the code for maintaining the OS clock? Can you confirm if the decrementer auto
-reloads or is manually reloaded? Why would CPU load affect the update of the OS clock. I would assume that you would
use a similar mechanism as the time-of-day clock I implemented in 3) above and increment some counter while within the
decrementer interrupt handler, no? My understanding is that there are very few places in the kernel where you lock out
interrupts and even then it is very, very short.
robert
