Re: CPU or core counting..
05/19/2009 4:49 PM
post29715
I believe the CD install image is /boot/build/finstall.build, so you could make your own CD that would run the
SMP kernel.
I've never played with Hyper-V, so I've know clue what the VM is claiming. QNX doesn't distinguish cores from
processors
from hyperthreads, it just thinks there are n processors, and it will use the standard ACPI tables for determining
the processors available (if that fails it will fall back to imps).
Colin
Mark Triable wrote:
> Hi Colin,
> Thanks for the pointer. Is it possible to change it and reburn to run an SMP kernel? I am not sure whether it would be
safe to hit a Vista/2008 loader with something else in order to see whether a hard disk install would change things.
> Live SMP CD would be useful to test for hardware issues. Then again ,only a single one though, one of the boxes is
refusing to boot from CD-ROM and no sign of .altboot but I guess I can easily swap drives.
> For VM scenarios, I am using Hyper-V on Server 2008 and although not officially supported QNX states CPU 2 failure
after I raise it from 2 to 4 on VM settings. Hence me wondering what the number identifies, a core or physical id? This
happens on both a dual physical * 2 core, and also on dual physical * 2 core * 2 hyperthreaded (8 hardware threads or
cpus as they would appear in NT Task Manager).
> Cheers,
> Mark
> http://community.qnx.com/sf/go/post29698
cburgess@qnx.com
