shared memory mapping question
05/07/2009 5:31 PM
post28982
I am running an ARM architecture and trying to use shared memory. I have read the docs on the 'special' cases for ARM
(specifically ARM9) memory management.
What I would like to do, and I thought the docs indicated this was possible, was to have process #1 create some shared
memory and map it using the following commands and flags.
fd = shm_open(fileNameArg, O_RDWR | O_CREAT | O_EXCL, 0777);
shm_ctl(fd, SHMCTL_ANON | SHMCTL_GLOBAL | SHMCTL_LOWERPROT, 0, sizeInBytes);
ptr = mmap( NULL, length, prot, flags, fd, offset)
My understanding is that the combination of SHMCTL_ANON | SHMCTL_GLOBAL | SHMCTL_LOWERPROT will place this memory in a
'global' address pool that will be accessible by other processes
In other words, Can I just pass the 'ptr' to process #2 and have it be able to access the memory at that address without
the need for process #2 to call mmap() ???
I have tried this in my system, and it doesn't seem to work, so maybe I am misunderstanding the docs.
The OS version is 6.4.0
Thanks for the help.
- Mike
Re: shared memory mapping question
05/08/2009 7:52 AM
post29006
In what way doesn't this work?
The following (cheesy) program worked for me on an omap5912 (ARM926) board.
Compiling it to generate a 'shm' executable gave me the following output:
# shm &
57353 running shm
# ptr = 0x80100000
setting 0 to 0xdeadbeef
hanging around...
# shm 0x80000000
using ptr=80000000
read deadbeef
This is the source:
#include <sys/mman.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
int
main(int argc, char *argv[])
void *ptr;
int fd;
if (argc == 2) {
ptr = (void *)strtoul(argv[1], 0, 0);
printf("using ptr=%x\n", ptr);
printf("read %x\n", *(unsigned *)ptr);
exit(0);
fd = shm_open("/shmfile", O_CREAT|O_EXCL|O_RDWR, 0666);
if (fd == -1) {
perror("shm_open");
exit(1);
shm_unlink("/shmfile");
if (shm_ctl(fd, SHMCTL_ANON|SHMCTL_GLOBAL|SHMCTL_LOWERPROT, 0, 4096) == -1) {
perror("shm_ctl");
exit(1);
ptr = mmap(0, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
if (ptr == MAP_FAILED) {
perror("mmap");
exit(1);
printf("ptr = 0x%x\n", ptr);
printf("setting %x to 0xdeadbeef\n", *(unsigned *)ptr);
*(unsigned *)ptr = 0xdeadbeef;
printf("hanging around...\n");
while (1)
exit(0);
Michael Cranston wrote:
> Hello,
without the need for process #2 to call mmap() ???
> - Mike
> http://community.qnx.com/sf/go/post28982
05/08/2009 8:53 AM
post29011
Thanks for the response.
The problem I am having is that process #1 gets memory at 0x80100000. I pass that address to process #2 and process #2
throws some sort of segmentation fault when it attempts to write to the memory.
Question. Why did you use 0x80000000 when the original ptr was 0x80000000?
- Mike
05/08/2009 9:47 AM
post29017
Can you post your source?
The 0x80000000 value I passed is because that is the address returned by
the mmap in the first instance of the program. The second invocation takes
that pointer value and accesses it without having first done an mmap in
that process - ie. the memory object is globally visible without an mmap.
Sunil.
2 throws some sort of segmentation fault when it attempts to write to the memory.
> Thanks,
> - Mike
> http://community.qnx.com/sf/go/post29011
05/08/2009 10:41 AM
post29031
Thanks again.
I didn't type that last question correctly. What I wanted to ask was why the address passed to the second process was
not exactly equal to the address returned by the first process.
0x80100000 for process #1
But you passed 0x80000000 to process #2
Why the difference?
Also, I assume that you cannot unmap the memory from the first process while accessing it in the second.
That would make it invalid memory again. Correct?
I can't post the source, but your example program is exactly what I am trying to do.
- Mike
05/08/2009 12:03 PM
post29057
Oops - the output I sent you had run the shm process twice, so there were
actually 2 global mappings in place. This meant that the 0x80000000 was
the mapping in the first process.
After a clean boot:
shm &
49160 running shm
# ptr = 0x80000000
hanging around...
# shm 0x80000000
using ptr=80000000
read deadbeef
You are correct that you cannot unmap the memory and expect it to work.
The memmgr can unmap pages in a global region if there are no remaining
active mmap's of that address range.
If you are doing exactly what my program does, I don't understand why
your code is not working (ie. why it gets a sigsegv).
How big is your mapping?
What processor/board are you running on?
Sunil.
> Thanks again.
> Why the difference?
> Thanks,
> - Mike
> http://community.qnx.com/sf/go/post29031
05/08/2009 1:51 PM
post29066
Hi Sunil,
I am currently running this on an i.mx27 development board from Freescale.
The memory mappings are generally 1 to 4 Kbytes. Some may be as large as 1Mbyte.
The code is written in C++, and the shared memory code used by both processes is in one library.
It originally mapped and unmapped as needed and the shared memory file name was passed between processes via messages.
It is a client server type application. I want to avoid the added delay of the map/unmap each time a server gets a
message.
I suspect my issue is that I may have unmapped the memory somewhere in the process and did not catch that yet. I will
keep digging and let you know what I find.
One last question. This should work the same way on x86 platforms, correct?
I do some of my development on virtual machines running neutrino natively.
Thanks again,
- Mike
> After a clean boot:
> shm &
> 49160 running shm
> # ptr = 0x80000000
> hanging around...
> # shm 0x80000000
> using ptr=80000000
> read deadbeef
> Sunil.
> > Thanks again.
> the address passed to the second process was not exactly equal to the address
> > Why the difference?
> trying to do.
> > Thanks,
> > - Mike
> > OSTech
05/08/2009 2:49 PM
post29072
I am pretty sure that this doesn't work on X86. The global address space thing, is (I think) unique to ARM...
05/12/2009 11:06 AM
post29271
Can someone confirm? I also think it's only working on ARM9, no where else, because actually, it should NOT work at all.
- Malte
05/12/2009 11:26 AM
post29276
Thanks for all the help.
I ran the test app provided here and it does work on my i.mx27 ARM9.
It does not work on x86.
- Mike
