Potential for memory corruption in handling of _PROC_SPAWN_ARGS messages?
03/24/2009 4:21 PM
post25140
Fellows,
While giving the kernel a once over with lint, I noticed this at procmgr_spawn.c:666 (no really!)
664 3317 xxxxx1 case _PROC_SPAWN_ARGS:
665 16513 peterv if(ctp->info.nd == ND_LOCAL_NODE && (lcp = ProcessStartup(ctp->info.pid, 0)) != (void *)-1) {
666 16089 peterv void *buff = &msg->spawn_args.i + sizeof msg->spawn_args.i;
667 16089 peterv unsigned off = 0;
668 16089 peterv unsigned len;
669 16089 peterv
670 16089 peterv while(msg->spawn_args.i.nbytes) {
671 16199 sebastien len = min(msg->spawn_args.i.nbytes, 512); //ctp->ctrl->msg_max_size - sizeof msg
->spawn_args.i);
672 16089 peterv if(MsgRead(lcp->rcvid, buff, len, msg->spawn_args.i.offset) == -1) {
673 16089 peterv return errno;
674 16089 peterv }
675 16089 peterv if(MsgWrite(ctp->rcvid, buff, len, off) == -1) {
676 16089 peterv return errno;
677 16089 peterv }
678 16089 peterv off += len;
679 16089 peterv msg->spawn_args.i.offset += len;
680 16089 peterv msg->spawn_args.i.nbytes -= len;
681 3317 xxxxx1 }
682 16089 peterv return EOK;
683 3317 xxxxx1 }
684 16089 peterv break;
This looks to me like a day zero bug: since the LHS of the addition is not char * - it is struct _proc_spawn_args * -
surely that should read:
void * buff = & msg->spawn_args.i + 1;
The comment for r16199 ("Temp fix for handling large args") makes me wonder if this was the problem that was intended to
be fixed. I wonder if this is in some way related to the vfork() oddities?
Neil
Re: Potential for memory corruption in handling of _PROC_SPAWN_ARGS
messages?
03/24/2009 10:30 PM
post25147
messages?
It certainly does seem to be in error, but I'm not convinced it is causing an issue, since ctp->msg_max_size
is, in fact, 1568, so the comment appears to be erroneous.
sizeof(msg->spawn_args.i) is 16, so 16 * 16 is only 256, which still gives you way more than 512 to work with.
Still, it's obviously not intended behaviour... of course, nothing about this code says "Obvious" :-)
Neil Schellenberger wrote:
> Fellows,
> 669 16089 peterv
msg->spawn_args.i);
> 674 16089 peterv }
> 677 16089 peterv }
> 681 3317 xxxxx1 }
> 683 3317 xxxxx1 }
to be fixed. I wonder if this is in some way related to the vfork() oddities?
> Regards,
> Neil
> http://community.qnx.com/sf/go/post25140
cburgess@qnx.com
03/25/2009 1:35 PM
post25212
Yeah, I figured that 512 was probably small enough to avoid any
problems. Just for my own edification, where did you find the
msg_max_size of 1568?
> > Fellows,
> > 669 16089 peterv
msg->spawn_args.i);
> > 674 16089 peterv }
> > 677 16089 peterv }
> > 681 3317 xxxxx1 }
> > 683 3317 xxxxx1 }
- surely that should read:
intended to be fixed. I wonder if this is in some way related to the vfork() oddities?
> > Regards,
> > Neil
> > OSTech
messages?
03/25/2009 1:43 PM
post25215
messages?
It's a calculate value in dispatch_create or some-such location. I did the cheesy route and loaded
procnto up in the debugger. :-)
>>> Fellows,
>>> 669 16089 peterv
msg->spawn_args.i);
>>> 674 16089 peterv }
>>> 677 16089 peterv }
>>> 681 3317 xxxxx1 }
>>> 683 3317 xxxxx1 }
>>> Regards,
>>> Neil
>>> OSTech
> http://community.qnx.com/sf/go/post25212
cburgess@qnx.com
RE: Potential for memory corruption in handling of _PROC_SPAWN_ARGS messages?
03/25/2009 1:49 PM
post25218
I see a line in pathmgr that does
msg_max_size = POSIX_PATH_MAX + sizeof (struct _connect)
Which I bet is 1568.
David
> From: Colin Burgess [mailto:community-noreply@qnx.com]
> Sent: March 25, 2009 1:44 PM
> To: ostech-core_os
> Subject: Re: Potential for memory corruption in handling of
> location. I did the cheesy route and loaded procnto up in
> the debugger. :-)
> >> causing an issue, since ctp->msg_max_size is, in fact,
> >>> Fellows,
> (void *)-1) {
> >>> 669 16089 peterv
> >>> 670 16089 peterv
> - sizeof msg->spawn_args.i);
> >>> 672 16089 peterv
> >>> 674 16089 peterv }
> >>> 675 16089 peterv
> >>> 677 16089 peterv }
> >>> 679 16089 peterv
> >>> 680 16089 peterv
> >>> 681 3317 xxxxx1 }
> >>> 683 3317 xxxxx1 }
> intended to be fixed. I wonder if this is in some way...
03/25/2009 2:18 PM
post25221
Thanks, David!
Does anyone know if we effectively guarantee that this is the only
msg_max_size ever used a) in this case; or b) in general? Given tricks
like the one in question, one presumes that it is conceivable that there
are spots where it will be smaller.
> David
> > To: ostech-core_os
> > the debugger. :-)
> > >>> Fellows,
> > (void *)-1) {
> > >>> 669 16089 peterv
> > >>> 670 16089 peterv
> > >>> 672 16089 peterv
> > >>> 674 16089 peterv }
> > >>> 675 16089 peterv
> > >>> 677 16089 peterv }
> > >>> 679 16089 peterv
> > >>> 680 16089 peterv
> > >>> 681 3317 xxxxx1 ...
messages?
03/25/2009 2:58 PM
post25230
messages?
I think that the 512 constant is icky icky poo and should be dynamically calculated. This particular case is
not high runner an even so is not on the critical performance path.
The casting error too should be fixed.
Cheers,
Colin
> Thanks, David!
>> David
>>> To: ostech-core_os
>>> the debugger. :-)
>>>>>> Fellows,
>>> (void *)-1) {
>>>>>> 669 16089 peterv
>>>>>> 670 16089 peterv
>>>>>> 672 16089 peterv
>>>>>> 674 16089 peterv }
>>>>>> 675 16089 peterv
>>>>>> 676 16089 peterv return...
03/25/2009 3:31 PM
post25244
Yup, I've already fixed both of these things in my candidate lint
patches. There will be a CI soon.
> Cheers,
> Colin
> > Thanks, David!
> >> David
> >>> To: ostech-core_os
> >>> the debugger. :-)
> >>>>>> Fellows,
> >>> (void *)-1) {
> >>>>>> 669 16089 peterv
> >>>>>> 670 16089 peterv
