io-usb interfering with PCI express device driver? (interrupt sharing)
02/16/2009 6:34 AM
post22306
My test system - Neutrino 6.4 on Intel Quadcore - has a data card in a PCI express slot. The card handles audio I/O
over DMA and generates interrupts at a 12 kHz rate.
Now the weird part:
When I run the driver for the card, I see (using the command "top") that the io-usb process suddenly uses 25% of the
processor.
The strange thing is: I do not have anything connected to USB.
If I slay io-usb, the driver for my PCIe card no longer works, i.e. the interrupts don't seem to get handled anymore.
I also tried removing all USB drivers from my build file. The system boots ok, but the PCIe card no longer works (same
behaviour as if I slay io-usb).
(The same interrupt line is also shared by the network card, but if I slay this driver, my PCIe card still works).
The driver accesses the card via the pci_attach_device() et al. functions, so I don't see any need for usb.
--> The only connection I see is that the UHCI part of the usb shares the interrupt with the PCIe card.
Could this be a problem of the io-usb driver?
Has anybody had similar experiences?
~Lorenz
