RE: Interrupt handling in QNX
02/11/2009 7:43 AM
post21955
yes, you will have access to the thread's local data, to the
global static data, the heap and the stack.
The <area> and <size> arguments to the isr can be used, for
example, to have the same piece of code service different
devices (prepare a descriptor structure fro each device,
and attach a generic ISR to the interrupt, providing the
descriptor as the argument).
- Thomas
> From: sathish kumar [mailto:community-noreply@qnx.com]
> Sent: 11 February 2009 13:35
> To: ostech-core_os
> Subject: Interrupt handling in QNX
> Hi All,
> When an interrupt occurs in the hardware, the QNX interrupt
> redirector loads the thread table entry and context of the
> thread which the ISR is contained will be loaded. Does this
> mean that the context of the entire process in which the
> thread is a part is loaded or just the threads local data
> section. Can i then access the global variables in the heap
> area in ISR handler. Then in InterruptAttach( int intr,const
> struct sigevent * (* handler)(void *, int),const void *
> area,int size,unsigned flags) there is an area argument which
> is not paged out . Could someone clarify why this area is
> required if the entire context is loaded when the ISR occurs.
> Thanks,
> http://community.qnx.com/sf/go/post21954
