Re: Setting remote node System Time/Clock?
02/05/2009 12:30 PM
post21494
If you have ntp servers available (even just using the one board with
the clock chip) you can use ntpdate to set the initial time. Otherwise
you have to roll your own. (Popular approaches include rdate,
time/daytime, active or passive ssh script, etc.)
On Thu, 2009-02-05 at 06:45 -0500, Marc Roessler wrote:
> We have a multi-uC-System where only one controller has a clock chip, so the others all wake up with time "00:00:00 ..
> So how do we set the time of the "slave" nodes?
> Of course there is NTPd... which bails out if the difference between the current time and the is-to-be-time is too
large (which without doubt is the case after booting).
> Then there is the possibility of setting the time "manually" to make NTPd's job a bit easier, but this requires that I
set up my own protocol/resource manager for the CPUs to talk with each other, because I can't remotely set another
CPU's time via the shell tools - correct?
> This is all an ugly kludge...
> So there must be a "nice" and QNX-approven way of doing this, right? After all, this is a problem that I expect to
occur on a daily basis...
> Thanks & Greetings,
> Marc
> http://community.qnx.com/sf/go/post21463
02/05/2009 4:52 PM
post21548
> , this is a problem that I expect to occur on a daily basis...
I may be missing something, but doesn't "rtc [-s] net <node>" do what you require?
Rob Rutherford
