Forum Topic - Choosing between libraries with same API at run-time: (4 Items)
I wish to write a program that at run-time can choose between libc's mqueue (mq_*) API and libmq.so's API.
Since they have exactly the same function names (mq_send, mq_receive, etc.), how can I link to both libraries but at
runtime choose which actual implementation's code to execute?
The purpose of this application is so that the user can at run-time decide if they want to run a performance test with
mq or mqueue.
-asherk
RE: Choosing between libraries with same API at run-time
You write youn own library, implement the API
mq_open()/mq_send()/mq_receive()/..., has your application link to your
own library.
During the initilize period, (or the first call of a mq_open() into your
library), you find out the 2 set of mq_* functions.
	dlopen("libc.so.3", ...)
	libc_mq_open = dlsym(..., "mq_open");
	dlopen("libmq.so", ...)
	libmq_mq_open = dlsym(..., "mq_open");
And they you decided how to switch between the 2.
-xtang
> From: Andrew Sherk [mailto:community-noreply@qnx.com]
> Sent: Monday, February 02, 2009 12:03 PM
> To: ostech-core_os
> Subject: Choosing between libraries with same API at run-time
> Hello,
> mq or mqueue.
> -asherk
> http://community.qnx.com/sf/go/post21237
Re: Choosing between libraries with same API at run-time
Actually, if you don't need dynamic switch. There is much easy way.
Write your test application normally, link it with libc.
If you run it directly, it use mq_* in libc.
If you want to use libmq, try this:
 # LD_PRELOAD=/full/path/libmq.so ./mytestapp
ELF also specifies DT_FILTER and DT_AUXILIARY to help with this sort of
thing, but I don't think our runtime loader supports them at the moment.
> http://community.qnx.com/sf/go/post21240
