01/24/2009 10:35 AM
post20768
I am not sure that this is the right forum for this, but I think I have identified a bug/deficiency in tinit. I also
believe that I have a fix for it.
The basic problem: If a device listed in /etc/config/ttys does not exist at the time tinit starts, it will (probably)
never supervise that device ever. On the other hand, if the device exists at the time tinit starts and then disappears
(the resource manager quits/dies, etc.,) then the device will be "taken over" again when it is recreated.
I believe that the core of the problem is this code (in the start() function):
<snip>
pid_t start(struct tty_entry *ttp, int session) {
char *argv[MAXARGS];
char *src, *dst, *cmd;
char buf[100];
struct inheritance inherit;
struct termios tios;
int fds[3] = {0, 1, 2}, i;
close(0);
if(open(ttp->devname, O_RDWR) == -1)
return(-1);
</snip>
I believe that the solution is to replace the last two lines of the snippet with:
if(open(ttp->devname, O_RDWR) == -1) {
ttp->pid = -1;
return( ttp->pid );
The rationale is pretty simple. The "tty->pid == -1" condition is the trigger for tinit to retry opening the device and
starting the controlling program. If the device has never been opened, the tty->pid field is left uninitialized,
probably will not contain -1, and will never ever be retried again.
I may have misunderstood something, but I believe that this is what is happening (as seen on my system).
