01/09/2009 2:42 PM
post19783
Is the SPAWN_PADDR64_SAFE flag pass down the children?
We do on -P pterm xxx and it seems the program xxx is not allow to run above 4G.
01/09/2009 4:00 PM
post19791
The flag isn't inherited in further spawns. This is to avoid unintended
consequences such as trying to figure out why some task/driver is
failing randomly due to large spawn chains or accidental environment
inheritance.
The exception would be if you fork(). The address space attributes are
copied since there is really no other way to do it.
Cheers,
Adam
QNX Software Systems
[ amallory@qnx.com ]
With a PC, I always felt limited by the software available.
On Unix, I am limited only by my knowledge.
--Peter J. Schoenster
> From: Mario Charest [mailto:community-noreply@qnx.com]
> Sent: Friday, January 09, 2009 2:42 PM
> To: ostech-core_os
> Subject: SPAWN_PADDR64_SAFE
> above 4G.
> http://community.qnx.com/sf/go/post19783
01/11/2009 5:15 PM
post19815
Maybe a propagate type of flag then?
Because it makes think like on -P sh ...., or on -P pterm program messy to use
we have to change all our script to "on -P pterm program" to "on pterm on -P program" which isn't so bad unless you do
a sin and see all the on running.
Sent: Friday, January 09, 2009 4:00 PM
To: ostech-core_os
Subject: RE: SPAWN_PADDR64_SAFE
inheritance.
Cheers,
Adam
> To: ostech-core_os
> above 4G.
OSTech
http://community.qnx.com/sf/go/post19791
01/12/2009 9:55 AM
post19843
Another spawn flag? Ugh, I don't thing we'll want to do that. Once a
flag is in place we'll have to support it forever and they aren't
infinite in number available anyways.
In this scenario, I would suggest writing a custom launcher for your app
and then spawning that launcher to ensure the flag is set properly no
matter how the spawn chain you have setup occurs.
Cheers,
Adam
> Sent: Sunday, January 11, 2009 5:16 PM
> To: ostech-core_os
messy
> to use
pterm on
> -P program" which isn't so bad unless you do a sin and see all the on
> running.
> From: Adam Mallory [community-noreply@qnx.com]
> To: ostech-core_os
unintended
> inheritance.
are
> Cheers,
> Adam
> > To: ostech-core_os
run
> > above 4G.
> > OSTech
> http://community.qnx.com/sf/go/post19815
01/12/2009 10:21 AM
post19847
> From: Adam Mallory [mailto:community-noreply@qnx.com]
> Sent: January-12-09 9:55 AM
> To: ostech-core_os
> app
Not sure what you mean by launcher?
> Cheers,
> Adam
> > To: ostech-core_os
> messy
> > to use
> pterm on
> on
> > running.
> > To: ostech-core_os
> unintended
> > inheritance.
> are
> > Cheers,
> > Adam
> > > To: ostech-core_os
> run
> > > above 4G.
> > > OSTech
> > OSTech
> > OSTech
> http://community.qnx.com/sf/go/post19843
01/12/2009 11:21 AM
post19865
A custom application that spawns the app with the flags you wish.
Cheers,
Adam
> > Cheers,
> > Adam
> > > To: ostech-core_os
> > messy
> > > to use
> > pterm on
> > on
> > > running.
> > > To: ostech-core_os
> > unintended
environment
> > > inheritance.
attributes
> > are
> > > Cheers,
> > > Adam
> > > > To: ostech-core_os
to
> > run
> > > > above 4G.
> > > > OSTech
> > > OSTech
> > > OSTech
> > OSTech
01/12/2009 11:23 AM
post19867
> Sent: January-12-09 11:21 AM
> To: ostech-core_os
How would that be different than using "on -P". A custom launcher would solve the pterm <program> case.
> Cheers,
> Adam
> > > Cheers,
> > > Adam
> > > > To: ostech-core_os
> program
> > > messy
> > > > to use
> > > pterm on
> the
> > > on
> > > > running.
> > > > To: ostech-core_os
> > > unintended
> environment
> > > > inheritance.
> attributes
> > > are
> > > > Cheers,
> > > > Adam
> > > > > To: ostech-core_os
> to
> > > run
01/12/2009 11:31 AM
post19870
would
It's different because you would use on (no -P) to spawn the pterm with
the command of spawning the launcher instead of trying to inherit the
attribute down the chain.
Cheers,
Adam
01/12/2009 11:39 AM
post19876
> Sent: January-12-09 11:32 AM
> To: ostech-core_os
> would
Our biggest system starts about 50 pterms. That solution doesn`t really apply.
> Cheers,
> Adam
> http://community.qnx.com/sf/go/post19870
01/12/2009 1:28 PM
post19892
really
> apply.
I'm not sure why not; it's work sure but nothing too difficult. If you
feel that strongly about it, you are welcome to submit a feature request
of course.
Cheers,
Adam
01/12/2009 1:44 PM
post19894
> Sent: January-12-09 1:29 PM
> To: ostech-core_os
> really apply.
It`s the same thing as doing "on -n<node> pterm on -P <program>" which is what we had to do and that's messy.
> request of course.
Nah, I'm mainly trying to make the point that usage of over 4Gig of address space is not user-friendly. I trust that you
have given much thought about this but it's my personal option the SPAWN_PADDR64_SAFE flag should be somehow
inheritable.
Mario out ;-)
01/12/2009 2:07 PM
post19897
> address space is not user-friendly. I trust that you have given much
flag
> should be somehow inheritable.
Well, it was more of a compromise of not breaking existing software,
allowing them to optionally exploit the larger memory without changing
code (ie. launcher) and not creating a configuration nightmare by
allowing inheritance or too much transparency since failure could go
undetected for long times.
All of that while doing the extension in a way that allowed a much
easier integration for customers compared to the methods used by Windows
(ie. AWE) and other Oss with memory mapped file games.
I don't disagree with you on a purely technical level - more tweaking
ability can't be bad. The pragmatic side of me thinks that I'd rather
err on the side of correct but reserved behaviour versus maximum memory
usage and some hard to detect and debug errors that can masquerade as
data corruption, crashed OS etc. That's just me though.
Initially I thought marking the binaries themselves would have been much
better. The problem was that due to a variety of reasons the time line
was tight and quite limited where changes could be made when I got
involved. Perhaps re-examining that would be more fruitful than adding
yet another flag to an already complicated and well abused API. ;)
Thanks for the feedback though! While we may not agree, it's certainly
always appreciated.
Cheers,
Adam
