Forum Topic - Questions about mmap():
I've been tackling half a dozen PRs about the docs for mmap(), and I have a few questions (and a much better
understanding of memory mapping):
1. The header file defines these flags that aren't documented:
    - MAP_PRIVATEANON -- I think this is deprecated in favour of MAP_PRIVATE | MAP_ANON (because you can also have
shared anonymous memory)
    - MAP_NORESERVE, MAP_RENAME -- I don't think these are used in our code
    - MAP_ELF
    - MAP_BELOW (but MAP_BELOW16M is documented)
    - MAP_SYSRAM
  Should any of these be documented?
2. As far as I can tell, only MAP_PRIVATE, MAP_SHARED, and MAP_FIXED are POSIX. Is this correct, and should the docs
point this out?
3. POSIX says that mmap() can give an error of ENOTSUP if the implementation doesn't support MAP_FIXED or MAP_PRIVATE,
or if the implementation doesn't support the given combination of PROT_* flags. I know we support MAP_FIXED and
MAP_PRIVATE, so that part doesn't apply, but does the second?
4. One of the PRs asks for an example of memory-mapped files. I cooked up one, but I doubt that it's very good (although
 it no longer core dumps). Does anyone have a good (but short) example that could go in the docs?
5. The docs say that msync() might not work on all filesystems. The PR mentions that a filesystem needs to support the
_IO_MMAP message for memory-mapped files  to work. Does anyone know of any QNX ones that don't support this message?
Thanks.
RE: Questions about mmap()
Regarding the flags:
MAP_PRIVATEANON, if used in an mmap call, gets translated to
MAP_PRIVATE|MAP_ANON.  So, no difference.
MAP_NORESERVE and MAP_RENAME seems to be Sun things -- they have no
effect in our code if specified.  For documentation, maybe just say
they're there for compatibility and have no effect.
MAP_BELOW -- this one looks like it only has an effect on systems with
cache colours, but its not clear what it means from the code.  I'll let
somebody else comment on it...
MAP_ELF is (obviously) used to indicate that the memory is an ELF
object.  Its used by the program loader.  I don't know if it should ever
be used by "normal" programs.  Again, I'll have to let somebody else
comment.
MAP_SYSRAM is used internally (bit of a kludge, really) and will result
in EINVAL if given to the mmap call.
Doug
Re: Questions about mmap()
Actually, it's an output only status flag for the DCMD_PROC_MAPINFO,
DCMD_PROC_PAGEDATA devctl()'s (similar to the PG_* bits). Personally, I
wouldn't have put that flag in the MAP_* constants, but that's where it is.
	Brian
Thanks, Doug and Brian, for the information. In the interests of keeping this thread alive, here's what I came up for a
simple example of memory-mapped files. It reads a section from a text file, prints it, and then maps the same section
into memory and prints it from there:
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/mman.h>
#define SOME_OFFSET 100
#define SOME_LEN 50
int main () {
	int fd;
	void *addr;
	char buf[SOME_LEN+1];
	fd = open ("/tmp/000-log", O_RDWR);
	/* Read the file into a buffer: */
	lseek(fd, SOME_OFFSET, SEEK_SET);
	memset (buf, 0, SOME_LEN+1);
	read(fd, buf, SOME_LEN);
	printf ("Read from the file: \n%s\n\n", buf);
	/* Map the file into memory: */
	addr = mmap (NULL, SOME_LEN, PROT_READ|PROT_WRITE, MAP_SHARED,
				 fd, SOME_OFFSET);
	if (addr == MAP_FAILED) {
		perror ("mmap() failed");
	else {
		printf ("From the memory-mapped file: \n%.50s\n", (char *)addr);
	return EXIT_SUCCESS;
It works, but is it a good example? Any other comments?
Yeah, it looks perfectly reasonable for a simple example.  You could, of
course, get much more complex if you wanted to...
Doug
From: Steve Reid [mailto:community-noreply@qnx.com]
Sent: Wednesday, December 17, 2008 10:07 AM
To: ostech-core_os
Subject: Re: Questions about mmap()
this thread alive, here's what I came up for a simple example of
then maps the same section into memory and prints it from there:
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define SOME_LEN 50
int main () {
	int fd;
	void *addr;
				 fd, SOME_OFFSET);
	else {
*)addr);
OSTech
http://community.qnx.com/sf/go/post18821
Re: RE: Questions about mmap()
is it possible to map a file to a specific hardware address ?
E.g by replacing the NULL address in the mmap call:  addr = mmap (NULL, SOME_LEN, PROT_READ|PROT_WRITE, MAP_SHARED,  ??
--Armin
> Doug
> To: ostech-core_os
> #include <fcntl.h>
> #include <stdio.h>
> #include <stdlib.h>
> #include <string.h>
> #define SOME_LEN 50
> int main () {
> 	int fd;
> 	void *addr;
> 				 fd, SOME_OFFSET);
> 	else {
> *)addr);
To do that, create a shared memory object, then use shm_ctl() with SHMCTL_PHYS to associate the memory object with
a specific physical location.
Or, in your bsp setup a typed memory name and use the posix typed memory api
Armin Steinhoff wrote:
> Hello,
> --Armin
>> Doug
>> -----Original Message-----
>> To: ostech-core_os
>> #include <fcntl.h>
>> #include <stdio.h>
>> #include <stdlib.h>
>> #include <string.h>
>> #define SOME_LEN 50
>> int main () {
>> 	int fd;
>> 	void *addr;
>> 				 fd, SOME_OFFSET);
>> 	else {
>> *)addr);
>> OSTech
> http://community.qnx.com/sf/go/post28799
cburgess@qnx.com
