Forum Topic - Using pulses within the resource Manager Framework: (3 Items)
we're currently designing our system architecture.
We'd like one application to talk to another by accessing the applications's virtual /dev/app-ctrl device (i.e. resource
 manager concept).
Is it possible to send pulses across this device?
How will this all fit with the resource manager framework?
Greetings,
 Marc
RE: Using pulses within the resource Manager Framework
what exactly do you mean by "send pulses across this device" ?
You can send pulses to the resource manager and handle them;
this is described in the docs under
  QNX Neutrino RTOS / Programmer's Guide / Writing a Resource Manager /
Handling private messages and pulses
or online:
http://www.qnx.com/developers/docs/6.3.2/neutrino/prog/resmgr.html#HANDL
ING_PRIVATE_MSG
To have the resource manager send a pulse to the client, use
 MsgDeliverEvent() .  See:
  QNX Neutrino RTOS / Library reference / M / MsgDeliverEvent(),
MsgDeliverEvent_r()
http://www.qnx.com/developers/docs/6.4.0/neutrino/lib_ref/m/msgdeliverev
ent.html
Can you elaborate a bit on your specific use case?
- Thomas
> From: Marc Roessler [mailto:community-noreply@qnx.com]
> Sent: 15 December 2008 11:08
> To: ostech-core_os
> Subject: Using pulses within the resource Manager Framework
> manager concept).
> Greetings,
>  Marc
> http://community.qnx.com/sf/go/post18581
Re: RE: Using pulses within the resource Manager Framework
Well, by "sending pulses across a device" i mean exactly that ;)
I'll elabroate a bit..
Application A is the master
Application B is the slave
The design is inherently asynchronous - this is not our typical "write one block of data and return" like in the driver
cookbooks, but rather "switch to mode X and continue processing in this mode infinitely (even if A dies).. and wake me
in case any errors occur along the way"
B creates /dev/B-ctrl
A opens /dev/B-ctrl and sends commands to B (MsgSend/MsgReceive)
In order for B to signal to A asynchronously (e.g. for errors/status changes), I planned for B to send a pulse to A...
but not via a different channel, but also via this already opened channel (/dev/B-ctrl).
But the problem is i really don't see any easy and clean way to do this in the resource manager framework... of course
you can hook your read and write and devctl handlers here and there... but pulses, asynchronously?
Is synchronous messageing the right choice here anyway? You know that old joke with the multi-purpose-tool "hammer" and
all the nails..
Greetings,
 Marc
