RE: Shared mutex seems to cause the kernel to freak out
11/26/2008 2:07 PM
post17415
Hi Niklas,
I've opened PR63369 to track this issue. Thanks for the report!
Neil
Re: Shared mutex seems to cause the kernel to freak out
02/25/2009 8:09 AM
post22884
Hi Niklas
Did you get a solution for this ?
Could you tell a bit about how you managed to build boost 1_37?
I am using some of the boost libraries for some test on QNX 6.4
I have tried to build boost 1.38, everything build except serialization and python. Using the ordinary
./configure --without-libraries=python --without-icu
make install
it is failing on BZIP2 and that std::va_list is not exciting in Dinkums C++ library
Trying to build 1.37 the same way didn't succeed because of problems of make bjam. But forcing it to use the bjam from
the build of 1.38 helped a lot. If you like I can inform you about the status when finished.
./configure --with-bjam=/usr/local/bin/bjam --without-libraries=python --without-icu
make install
Yours
Flemming
