A bug in pthread_mutex_unlock()
11/12/2008 7:44 AM
post16451
Hi All
I would like to let you know about a bug I have discovered after an assertion check triggered in my code.
Consider the following scenario. A parent thread starts a child thread and waits for an event from it. Here is a typical
simplified pseudocode for this synchronization model.
struct Event
bool bState;
pthread_condr_t cCondvar;
pthread_mutex_t mMutex;
// Parent thread execution flow
Event eChildEvent; // Event structure is allocated and initialized on stack
pthread_create(..., &ChildThread, &eChildEvent, ...); // A child thread is started and a pointer to event is passed as
a parameter to it
// Now, wait for an event from the child thread
pthread_mutex_lock(&eChildEvent.mMutex); // <-- B
if (!eChildEvent.bState)
pthread_cond_wait(&eChildEvent.cCondvar, &eChildEvent.mMutex);
pthread_mutex_unlock(&eChildEvent.mMutex);
... // Parent thread continues its execution
int ChildThread(Event *peNotifyEvent)
... // Do something
// Signal the event to let the parent continue
pthread_mutex_lock(&peNotifyEvent->mMutex);
peNotifyEvent->bState = true;
pthread_cond_broadcast(&peNotifyEvent->cCondvar);
pthread_mutex_unlock(&peNotifyEvent->mMutex); // <-- A
// peNotifyEvent is not used any more
... // Child thread continues its execution
Here, as soon as child thread signals the conditional variable, parent thread continues its execution and it is
acceptable (and preferable) for it to destroy eChildEvent immediately.
Now, let's take a look at implementation of pthread_mutex_unlock() in context marked as "<-- A" in child thread.
int
(pthread_mutex_unlock)(pthread_mutex_t *mutex) {
if((mutex->__owner & ~_NTO_SYNC_WAITING) == LIBC_TLS()->__owner) {
if(--mutex->__count <= 0 || (mutex->__count & _NTO_SYNC_COUNTMASK) == 0) {
mem_barrier();
if(__mutex_smp_xchg(&mutex->__owner, 0) & _NTO_SYNC_WAITING || mutex->__count & _NTO_SYNC_PRIOCEILING) {
return SyncMutexUnlock_r((sync_t *)mutex);
return EOK;
return EPERM;
Take a closer look at the last conditional operator
if(__mutex_smp_xchg(&mutex->__owner, 0) & _NTO_SYNC_WAITING || mutex->__count & _NTO_SYNC_PRIOCEILING) {...}
Here, as soon as __mutex_smp_xchg() is executed and zero is assigned for the owner field, the parent thread can capture the mutex in point marked as "<-- B", make sure that eChildEvent.bState is already true, unlock the mutex
and destroy everything. Right after that the stack (just as dynamic memory, if mutex would be allocated in it) can be
reused and a different value can be assigned to the memory where mutex->__count was located. So, now if execution
context switches back to child thread it examines mutex->__count field and finds _NTO_SYNC_PRIOCEILING bit signalled
(which was not the case while the mutex was alive). The child thread enters the kernel with SyncMutexUnlock_r() and gets
EINVAL from there, since the mutex had been already destroyed.
You must not access any mutex fields after you did "xchg" and moved zero into owner field. If you need anything from
mutext you must copy it to local variables beforehand.
I've discovered this issue with QNX 6.3.0 SP3, however the source of pthread_mutex_unlock() I've posted here has been
taken from SVN and it did not change from that time (if it was ever changed at all).
There is also another possible improvement I'd like to point you to.
Have a look at the second conditional operator in the function
if(--mutex->__count <= 0 || (mutex->__count & _NTO_SYNC_COUNTMASK) == 0) {...}
Here the count is first decremented and checked against zero directly and then it is masked with _NTO_SYNC_COUNTMASK and
checked against zero again. As far as I understand this is done to save one binary AND instruction since in most cases
there are no additional bits set in count flag and normally first...
Re: A bug in pthread_mutex_unlock()
11/12/2008 9:01 AM
post16460
I've created PR62921 to track the bug you found in the "__mutex_smp_xchg(&mutex->__owner, 0) " line of
pthread_mutex_unlock(). Thank you for reporting it.
Your second point:
> if((--mutex->__count & _NTO_SYNC_COUNTMASK) == 0) {...}
Hmm I don't think two statements are exactly equivalent. mutex->__count may already be less than zero -- which
would be
a bug. In which hase the your version would exacerbate the bug.
-ad
Oleh Derevenko wrote:
> Hi All
typical simplified pseudocode for this synchronization model.
> struct Event
> bool bState;
as a parameter to it
> ... // Do something
> int
> mem_barrier();
> return EOK;
> return EPERM;
capture the mutex in point marked as "<-- B", make sure that eChildEvent.bState is already true, unlock the mutex and
destroy everything. Right after that the stack (just as dynamic memory, if mutex would be allocated in it) can be reused
and a different value can be assigned to the memory where mutex->__count was located. So, now if execution context
switches back to child thread it examines mutex->__count field and finds _NTO_SYNC_PRIOCEILING bit signalled (which was
not the case while the mutex was alive). The child thread enters the kernel with SyncMutexUnlock_r() and gets EINVAL
from there, since the mutex had been already...
11/12/2008 9:29 AM
post16465
> Your second point:
> Hmm I don't think two statements are exactly equivalent. mutex->__count may already be less than zero -- which would
be
Mutex count should never be less than zero as a mutex can not be locked a negative count of times. Here "<=" comparison
was used merely as a precaution instead of "==". Anyway if mutex lock count is less than zero it means that the mutex
storage is corrupted or it somehow has been unlocked more times than locked. In these cases the library behavior is
undefined so, there is not much sense in protecting from them.
Aha... The mutex count field could normally be less than zero if _NTO_SYNC_NONRECURSIVE is set (the value of
_NTO_SYNC_NONRECURSIVE is 0x80000000). However presence of this flag does not affect handling of _NTO_SYNC_COUNTMASK
field (the count is still incremented even if _NTO_SYNC_NONRECURSIVE is set) and the field can be checked against zero
in any case.
11/12/2008 11:19 AM
post16477
> Your second point:
be
It's very strange, but the program does not work normally without first condition. :-[ ]
It does not crash, but does not work as well.
It looks like the kernel gets confused the threads are blocked on condvars while thread state shows they are blocked on
mutexes.
(gdb) i thr
4 process 5001338 () 0xb032e9f9 in SyncCondvarWait_r () from /lib/libc.so.2
3 process 5001338 () 0xb032dd29 in MsgReceive () from /lib/libc.so.2
2 process 5001338 () 0xb032e9f9 in SyncCondvarWait_r () from /lib/libc.so.2
* 1 process 5001338 () 0xb032e9f9 in SyncCondvarWait_r () from /lib/libc.so.2
(gdb) she pidin -p 5001338
pid tid name prio STATE Blocked
5001338 1 ../bin/crm.bin 30o MUTEX 5001338-04 #1
5001338 2 ../bin/crm.bin 30o MUTEX 5001338-01 #1
5001338 3 ../bin/crm.bin 10o RECEIVE 2
5001338 4 ../bin/crm.bin 30o CONDVAR 8116298
I'll try to make some more investigations to this phenomenon. Does anybody have any ideas why the first part is required
NB: Sure, I've moved decrement operator into the second part while removing the first one.
11/12/2008 12:19 PM
post16482
I guess I know... It looks like the kernel may not clear the count field for not recursive mutexes when mutex is
released in pthread_cond_wait()/pthread_cond_timedwait() and leave 1 in it. As a result, when another thread attempts to
signal the convar, there is 0x80000001 in count before mutex is locked, after lock it becomes 0x80000002 and then, on
unlock the count is decremented back to 0x80000001. The kernel expects that the libc clears the owner field for the not
recursive mutex even if count is not zero.
> > Your second point:
> already be less than zero -- which would be
> condition. :-[ ]
> while thread state shows they are blocked on mutexes.
> (gdb) i thr
> have any ideas why the first part is required?
> the first one.
04/06/2009 2:23 PM
post26116
I've seen a fix has been commited. That's great. :)
One more question.
int
int prioceiling;
mem_barrier();
prioceiling = mutex->__count & _NTO_SYNC_PRIOCEILING;
if((__mutex_smp_xchg(&mutex->__owner, 0) & _NTO_SYNC_WAITING) || prioceiling) {
return EOK;
return EPERM;
Why is mem_barrier() necessary if following __mutex_smp_xchg() is implicitly a memory barrier?
04/07/2009 11:33 AM
post26246
Allright, let me rephrase it. ;)
Two memory barriers in a row are redundand and unnecessary, aren't they?
> One more question.
> int
> int prioceiling;
> mem_barrier();
> return EOK;
> return EPERM;
> memory barrier?
04/08/2009 12:45 PM
post26420
That's sad if nobody understands code well enough to take the responsibility of carrying out a decision. :(
P.S. Greetings from Igor. ;)
> > One more question.
> > int
> > int prioceiling;
> > mem_barrier();
> > return EOK;
> > return EPERM;
> a
> > memory barrier?
04/09/2009 6:07 PM
post26653
I don't belive __mutex_smp_xchg() contains it's own memory barrier. All ofthe other references to it call some form of
memory barrier first.
04/10/2009 6:28 AM
post26670
Hi Attilla
> other references to it call some form of memory barrier first.
Let's have a look at your own (QNX) implementation of memory barrier.
#define __cpu_membarrier() ({ extern unsigned __cpu_flags; if(__cpu_flags & (1 << 15)) __asm__ __volatile__ ("mfence"); else
__asm __volatile__("lock; orb $0,0(%esp)"); })
Now let's have a look at implementation of memory barrier in MSVC 2005
FORCEINLINE
VOID
MemoryBarrier (
VOID
LONG Barrier;
__asm {
xchg Barrier, eax
Now let's have a look at implementation of _smp_xchg()
static __inline int __attribute__((__unused__)) _smp_xchg(volatile unsigned *__dst, unsigned __src) {
__asm__ __volatile__(
"xchgl %0,%1"
:"=r" (__src)
:"m" (__atomic_fool_gcc(__dst)), "0" (__src)
:"memory");
return __src;
Don't you see any similarities with memory barrier from MSVC?
All the locked memory access instructions (the ones with "lock" prefix) are implicitly the memory barriers.
Here is an excerpt from IA-32 Intel® Architecture Software Developer’s Manual (pay attention to the last paragraph).
7.2.4. Strengthening or Weakening the Memory Ordering Model
The IA-32 architecture provides several mechanisms for strengthening or weakening the
memory ordering model to handle special programming situations. These mechanisms include:
• The I/O instructions, locking instructions, the LOCK prefix, and serializing instructions
force stronger ordering on the processor.
• The SFENCE instruction (introduced to the IA-32 architecture in the Pentium III
processor) and the LFENCE and MFENCE instructions (introduced in the Pentium 4 and
Intel Xeon processors) provide memory ordering and serialization capability for specific
types of memory operations.
• The memory type range registers (MTRRs) can be used to strengthen or weaken memory
ordering for specific area of physical memory (see Section 10.11., “Memory Type Range
Registers (MTRRs)”). MTRRs are available only in the Pentium 4, Intel Xeon, and P6
family processors.
• The page attribute table (PAT) can be used to strengthen memory ordering for a specific
page or group of pages (see Section 10.12., “Page Attribute Table (PAT)”). The PAT is
available only in the Pentium 4, Intel Xeon, and Pentium III processors.
These mechanisms can be used as follows.
Memory mapped devices and other I/O devices on the bus are often sensitive to the order of
writes to their I/O buffers. I/O instructions can be used to (the IN and OUT instructions) impose
strong write ordering on such accesses as follows. Prior to executing an I/O instruction, the
processor waits for all previous instructions in the program to complete and for all buffered
writes to drain to memory. Only instruction fetch and page tables walks can pass I/O instructions.
Execution of subsequent instructions do not begin until the processor determines that the
I/O instruction has been completed.
Synchronization mechanisms in multiple-processor systems may depend upon a strong
memory-ordering model. Here, a program can use a locking instruction such as the XCHG
instruction or the LOCK prefix to insure that a read-modify-write operation on memory is
carried out atomically. Locking operations typically operate like I/O operations in that they wait
for all previous instructions to complete and for all buffered writes to drain to memory (see
Section 7.1.2., “Bus Locking”).
XCHG with one of arguments in memory always asserts LOCK# signal automatically. Another excerpt follows.
Exchanges the contents of the destination (first) and source (second) operands. The operands
can be two general-purpose registers or a register and a memory location. If a memory operand
is referenced, the processor’s locking protocol is automatically implemented for the duration of
the...
04/10/2009 5:19 PM
post26696
Oleh,
You could well be right, but as you yourself admit, you don't know about other architectures. As
Neil mentioned, we kinda busy right now. :-)
We're not going to remove a line of code that was explicitly added back in 1999 until we've thought it through,
and right now we have more pressing issues to address.
In the meantime, we will raise PR67271 to track this. We believe me when we say that we do appreciate your
input.
Cheers,
Colin
> Hi Attilla
else __asm __volatile__("lock; orb $0,0(%esp)"); })
> FORCEINLINE
> VOID
> MemoryBarrier (
> VOID
> LONG Barrier;
> __asm {
> xchg Barrier, eax
> "xchgl %0,%1"
> :"=r" (__src)
> :"memory");
> return __src;
> family processors.
> memory-ordering model....
04/11/2009 5:19 AM
post26708
As for other architectures... Even if there is _smp_xchg without a memory barrier in it on any platform (which I hardly
believe as it makes the feature itself practically useless) that only means that the memory barrier should be added to
it.
> architectures. As
> input.
RE: A bug in pthread_mutex_unlock()
04/10/2009 2:03 PM
post26679
The asm for it does have a "memory" constraint, but I haven't had a chance to check if that causes the compiler to
produce a proper SMP memory barrier on all platforms. (Things are a little busy around here right now ;-) Even so, I'm
inclined to leave things as they are until 6.4.1 is out the door.
From: Attilla Danko [mailto:community-noreply@qnx.com]
Sent: Thu 4/9/2009 6:07 PM
To: ostech-core_os
Subject: Re: A bug in pthread_mutex_unlock()
OSTech
http://community.qnx.com/sf/go/post26653
Re: RE: A bug in pthread_mutex_unlock()
04/10/2009 4:58 PM
post26690
Guys, do not mistake everything. "memory" clobbering constraint has nothing in common with CPU memory barrier.
"memory" constraint tells GCC that it can't cache expressions from memory after crossing the command. That is, normally,
GCC could reuse value evaluated earler unless it is marked with "volatile" but now it can't do it any more and must re-
read it from memory once again.
Memory barrier for processor is one of instructions (as I mentioned in previous post) that forces the proecssor to wait
until all pending writes to memory complete and does not allow it to start pre-fetching values for memory access
instructions that are scheduled for execution after the barrier. That is, the memory barrier ensures that everything
that has been scheduled for writing to memory if flushed to memory (or to processor cache to extent sufficient to be
recognized by other processors in the system) before crossing the barrier and none of the next reads start until
crossing the barrier. And no assembler constraints affect this - just some selected assembler instructions.
> check if that causes the compiler to produce a proper SMP memory barrier on
> I'm inclined to leave things as they are until 6.4.1 is out the door.
> To: ostech-core_os
RE: RE: A bug in pthread_mutex_unlock()
04/11/2009 2:23 PM
post26712
That's what I said: I wasn't certain that the compiler would emit an SMP barrier (and was pretty sure it wouldn't).
Note that there is no inherent reason that the compiler wouldn't choose to emit such an instruction for a memory
constraint, and on SMP machines it would make a certain amount of sense for it to do so. However, as I said, I don't
think it does.
From: Oleh Derevenko [mailto:community-noreply@qnx.com]
Sent: Fri 4/10/2009 4:58 PM
To: ostech-core_os
Subject: Re: RE: A bug in pthread_mutex_unlock()
> To: ostech-core_os
OSTech
http://community.qnx.com/sf/go/post26690
Re: RE: RE: A bug in pthread_mutex_unlock()
04/11/2009 3:37 PM
post26714
Neil, you do not need compiler to emit any additional instruction. "xchg mem,reg" is the memory barrier itself. It's not
only "mfence" that counts for the barrier but any of port I/O instructions as well as locked instructions (including
xchg).
> barrier (and was pretty sure it wouldn't). Note that there is no inherent
> memory constraint, and on SMP machines it would make a certain amount of sense
> for it to do so. However, as I said, I don't think it does.
RE: RE: RE: A bug in pthread_mutex_unlock()
04/12/2009 11:18 AM
post26725
Hi Oleh,
Yes, I'm aware that's the case on the x86. I was more concerned about the other architectures which we support.
Neil
Sent: Sat 4/11/2009 3:37 PM
To: ostech-core_os
Subject: Re: RE: RE: A bug in pthread_mutex_unlock()
xchg).
OSTech
http://community.qnx.com/sf/go/post26714
