How to know that thread is preempted?
11/07/2008 10:54 AM
post16202
I want to measure how much time function execution would take within function itself,
for example
void x() {
start = ClockCycles();
end = ClockCycles();
time = end-start;
Now if Thread where x is running gets preempted time would be wrong.
How can I know that? Any handlers I can install inside my app? Any other "time" related calls I can make instead, that
returns thread running time (or process time) instead of absolute time?
AW: How to know that thread is preempted?
11/07/2008 11:10 AM
post16208
I guess your aksing 'cause of the Application Profiler thing?!
I see two different things:
*1st - for doing profiling from k-traces
you don't need to mesaure the time at all on the target site, this yould be done on IDE site - cause you have all the
informations on the TraceEvent() entries
*2nd - for doing this on target site
a) maybe you can do this using dynamic event filtering
installing a handler on event RUNNING or/and others could give you some informations
b) in addition to do ClockCycles(), you can check the resulting delta against a 2nd delta you do on the THREAD_CPU_CLOCK
time
if this is "nearly" the same it should be OK
or
c) why not using THREAD_CPU_CLOCK *instead* of ClockCycles() ???
shouldn't this solve the problem?
OK it is more costley, but anything other?
/hp
>Von: Elena Laskavaia [mailto:community-noreply@qnx.com]
>Gesendet: Freitag, 7. November 2008 16:54
>An: ostech-core_os
>Betreff: How to know that thread is preempted?
>within function itself, for example
>void x() {
> time = end-start;
>OSTech
>http://community.qnx.com/sf/go/post16202
Management Board: Dr. Klaus Blickle (Chairman), Dr. Udo Hüls, Michael Mauser, Regis Baudot
Re: AW: How to know that thread is preempted?
11/07/2008 11:17 AM
post16211
we do it like this for our self made (sometimes sneaky) tools:
myClockId = ClockId(getpid(), pthread_self());
// check the id
rc = ClockTime(myClockId, 0, &timeStart);
//check rc
... do the stuff to measure ...
rc = ClockTime(myClockId, 0, &timeEnd);
//check rc
cpuNanos = (timeEnd - timeStart);
11/07/2008 11:22 AM
post16212
Yes, but ClockTime doesn't give you the same resolution as ClockCycles() - since it uses the OS accounting which is
coarse grained.
Elena you will have to attach to the THRUNNING event handler I think
> // check the id
> //check rc
> //check rc
> http://community.qnx.com/sf/go/post16211
cburgess@qnx.com
11/07/2008 11:27 AM
post16213
A gotcha with ClockCycles() is that you have to deal with CPU migration
on SMP - the values aren't necessarily synchronized between CPU's.
Brian
coarse grained.
> > // check the id
> > //check rc
> > //check rc
> > OSTech
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post16212
11/07/2008 11:42 AM
post16216
Is it related to tracelogger? Would it work on non-instrumented kernel?
> H
11/07/2008 11:44 AM
post16219
No. I can't think of a way to determine that you have been preempted on a non instrumented kernel.
But who would be foolish enough to run that? ;-)
Colin
>> H
> http://community.qnx.com/sf/go/post16216
cburgess@qnx.com
AW: AW: How to know that thread is preempted?
11/07/2008 11:46 AM
post16221
I know some ...
>Von: Colin Burgess [mailto:community-noreply@qnx.com]
>Gesendet: Freitag, 7. November 2008 17:44
>An: ostech-core_os
>Betreff: Re: AW: How to know that thread is preempted?
>Colin
>>> H
>> OSTech
>cburgess@qnx.com
>OSTech
>http://community.qnx.com/sf/go/post16219
11/07/2008 11:44 AM
post16220
no and no
dynamic event filtering does not need tracelogger
but it needs procnto-instr!
>Gesendet: Freitag, 7. November 2008 17:43
>An: ostech-core_os
>> H
>OSTech
11/07/2008 11:48 AM
post16222
for the event filter solution:
how do you handle nested preemtions?
and how can you quantify the preemptions?
you only can do interrupt restricted things inside your event filter/handler.
So in best case you do something like this
call void foo()
log f_enter in file.ptrace
... do some work
yield to thread X, event handler is called
log f_yield (pid, tid) in file.ptrace
... do some work
yield to thread Y, event handler is called
yield back to original thread, event handler is called
... do more work
log f_exit in file.ptrace
but this could only be done if the used file.ptrace is accessable inside the dynamic event handler functions.
which is not the fact, cause it's a normal file.
So making this file accessable through kernel memory would make it.
/hp
>Gesendet: Freitag, 7. November 2008 17:23
>An: ostech-core_os
>coarse grained.
>> myClockId = ClockId(getpid(), pthread_self()); // check the id
>> rc = ClockTime(myClockId, 0, &timeStart); //check rc
>> rc = ClockTime(myClockId, 0, &timeEnd); //check rc
>> OSTech
>cburgess@qnx.com
>OSTech
Re: AW: AW: How to know that thread is preempted?
11/07/2008 11:54 AM
post16225
Elena was not producing a log, she was measuring time spent.
The main thing that would have to change is that she would have to specify the times to count
in the event handler user data.
The event handler would maintain the time that we were READY so it could be subtracted from the elapsed ClockCycles()
time.
The way you are working below it would be better to use the SYSTEM function enter/exit codes like she does in her kernel
instrumentation based profiler. But she apparentely needs to add THRUNNING events into that too.
Colin
> call void foo()
> ... do some work
> ... do some work
> ... do more work
> /hp
>> An: ostech-core_os
>> coarse grained.
>>> OSTech
>> cburgess@qnx.com
>> OSTech
AW: AW: AW: How to know that thread is preempted?
11/07/2008 12:17 PM
post16228
I think it's about the profiling that's done using -finstrument-functions *without* traclogger
and for this case we need the log file.
I think you don't need additional events for the tracelogger functions profiling, you already have all the events
you need to do the accounting on IDE side.
I don't like the way I work below, because it's a YATL (yet another tracelogger logger)
so why not use tracelogger instead with some filters set.
or .... dtrace
/hp
>Gesendet: Freitag, 7. November 2008 17:54
>An: ostech-core_os
>Betreff: Re: AW: AW: How to know that thread is preempted?
>have to specify the times to count in the event handler user data.
>so it could be subtracted from the elapsed ClockCycles() time.
>Colin
>> call void foo()
>> ... do some work
>> yield to thread X, event handler is called log f_yield (pid, tid) in
>> file.ptrace ... do some work yield to thread Y, event handler is
>> called log f_yield (pid, tid) in file.ptrace yield back to original
>> thread, event handler is called ... do more work log f_exit in
>> file.ptrace
>> /hp
>>> An: ostech-core_os
>>> ClockCycles() - since it uses the OS accounting which is coarse
>>> grained.
>>>> OSTech
>>> cburgess@qnx.com
>>> OSTech
11/07/2008 12:42 PM
post16231
Thanks all for you suggestions!
If we go into details there are two scenarios:
- one is using instrumented kernel - right now we inject function enter/exit and
I think I can extract preemption event from the same log already.
- second is not using instrumented kernel and using "file" to log time spent (it is buffered, so it does not have to be
called from traceevent handler),
in this case I think I should use ClockTime as suggested earlier.
time.
kernel
> Colin
>> call void foo()
>> ... do some work
>> ... do some work
>> ... do more work
>> /hp
>>> An: ostech-core_os
>>> coarse grained.
>>>> OSTech
>>> cburgess@qnx.com
>>> OSTech
>> Chairman of the Supervisory...
11/07/2008 11:40 AM
post16215
> // check the id
This I have to call just ones per thread? and I can re-use it many times?
> //check rc
> //check rc
11/07/2008 11:43 AM
post16218
yes, as long as this thread exists.
But Colins' and Brians' comments should also be remarked.
Is the resolution we get from ClockTime() goog enough?
>Gesendet: Freitag, 7. November 2008 17:40
>An: ostech-core_os
>many times?
>> OSTech
>OSTech
>http://community.qnx.com/sf/go/post16215
