Forum Topic - API's to get information on mounted file systems???: (3 Items)
I'm in the process of porting the GIO module of glib to QNX and ran across some API's that are apparently lacking in
Neutrino. There are several functions in GIO that retrieve information about mounted volumes. Typically, on Linux or
FreeBSD systems one or more of the following functions are available:
setmntent()/getmntent()
These routines are used to access the file system description file /etc/fstab and the mounted file system description
file /etc/mtab.
OR
getmntinfo()
The getmntinfo() function returns an array of statfs structures describing each currently mounted file system (see
statfs(2)).
OR
mntctrl()
The mntctl subroutine is used to query the status of virtual file systems (also known as mounted file systems). Each
virtual file system (VFS) is described by a vmount structure. This structure is supplied when the VFS is created by the
vmount subroutine.
The GIO module uses at least one of the (above) APIs to implement its functionality. For now I've provided dummy "do-
nothing" functions for lack of a better substitute. I've looked through the QNX documentation (at least for 6.3.2) and
it doesn't appear to be anything equivalent for getting information on mounted file systems. Can anyone offer
suggestions/work-arounds that might provide the same functionality?
Re: API's to get information on mounted file systems???
file /etc/mtab.
> OR
> getmntinfo()
statfs(2)).
> OR
> mntctrl()
vmount subroutine.
I came across this as well and added getmntinfo() and getfsstat() to
libnbutil.  libnbutil ships with 6.4 or you can get it as part of
the networking project on the foundry.
I am using the 6.5.0 version of the BSP. The libnutil doesn't exit. Do these functions exist in this version, or should
they still be added. And if yes, where should they be added?
-Zahira
