Forum Topic - Porting QNX to new architecture: any manuals/tips/must-reads?:
Hi everyone,
  I'm investigating porting QNX to an in-house processor architecture. I've read through a few bird's-eye view
architecture "how QNX works" manuals and it looks like it will be a good fit for our applications. I've also grabbed the
 source and poked aorund the various system/ker/<arch> directories, and haven't found anything too scary in there.
  So, now it's time to dig deeper. I wonder, are there any manuals walking through the basic steps required to bring QNX
 up on a new architecture? This would be great but if there's no such thing, does anyone have some suggestions on things
 to look out for before getting stuck in a port? Or the best order in which to attack things?
Re: Porting QNX to new architecture: any manuals/tips/must-reads?
> Hi everyone,
Wow, how many years do you plan to invest in this project?  ;-)
Are there some more details about your in-house CPU?
Does it contain a MMU?
Do you have a working GNU Toolchain for it?
The count of years will depend on some of this details.
Regards
Michael
> > Hi everyone,
I'd hope to have _something_ going within 6 to 12 months. But that shouldn't be as crazy as it sounds, because:
Yes, mostly. Since we have no OS running, obviously programs are limited in what they can do currently. But we do have C
/C++ compilers going, brk(), printf(), just enough to debug stuff without an OS. But it's starting to hurt.
Unfortunately, there's nothing relevant to the OS side of things that has been published. If you're curious though, the
CPU is probably going to end up being called MDGRAPE-4, it is the successor to MDGRAPE-3 you can read about here:
http://en.wikipedia.org/wiki/MDGRAPE-3
Yes, it does. It is nothing too fancy, but it has hardware support for dealing with TLB misses, and it also supports a
number of different page sizes. (As I hope QNX does? I'd better go have a look..)
Also, since the processor is not fixed in final silicon just yet, there is still some time to tweak the MMU.
Well, a lot of the toolchain is done. It can't be _too_ much of a nightmare??
That reminds me of one last point: our hardware platform is pretty "simple", in that we don't have lots of strange
devices that need drivers to be written. It's going to be memory and CPUs on the boards and not a whole lot else.
RE: Porting QNX to new architecture: any manuals/tips/must-reads?
Interesting. Are you also going to do 24 core SMP?
When you say "only CPU and memory", how about networking? How is data
moving between the "units"?
-xtang
From: Duraid Madina [mailto:community-noreply@qnx.com]
Sent: October 20, 2008 8:16 PM
To: ostech-core_os
Subject: Re: Porting QNX to new architecture: any
> > Hi everyone,
architecture.
in what they can do currently. But we do have C/C++ compilers going,
starting to hurt.
has been published. If you're curious though, the CPU is probably going
dealing with TLB misses, and it also supports a number of different page
nightmare??
"simple", in that we don't have lots of strange devices that need
OSTech
http://community.qnx.com/sf/go/post15288
Re: RE: Porting QNX to new architecture: any manuals/tips/must-reads?
> -xtang
The chips are multicore and we need to get that going, yes. At this stage we don't have any plans for SMP beyond that.
So boards might have more than one chip but it'll be one OS instance for each of those.
Other than JTAG and a memory interface, we expect the only other I/Os to be generic parallel interfaces. If we could get
 these going as /dev/blah, we'd be set. We have no particular need to set up ethernet, say.
> manuals walking through the basic steps required to bring QNX up on a new
> architecture?
The "services/system/doc/PORTING" document is about it as far as stuff
being written down.
As others have noted, you need a 32 bit CPU with a full featured MMU or
you're going to be in a world of hurt.
> being written down.
Thanks! I completely missed this gem!
Uh oh: by 32 bit CPU, you mean "32 bits plus", right? Because our target is 64-bit. :( Or is 64-bits an absolute
nightmare for QNX?
We can run on 64bit chips, but we currently only support a 32bit model.  For example, we run on 64bit MIPS processors,
we save/restore the full 64bit
regs, but the compiler believes that it runs in a 32bit world.
True 64bit has yet to be done... although it would be doable.
>> being written down.
nightmare for QNX?
> http://community.qnx.com/sf/go/post15293
cburgess@qnx.com
> example, we run on 64bit MIPS processors, we save/restore the full 64bit
OK, that is a relief. On our side, there aren't any 32-bit toolchain issues I'm aware of, other than everyone just
generally assuming things would be LP64 so the 32-bit side of things has gotten ignored a bit.
Could you guess how much work might be involved? As far as 64-bit MIPS goes, is it mostly a toolchain issue, or kernel
rework, or just patching up not-quite-64-bit-clean bits of code here and there? (Hopefully not everywhere :)
> 64-bit. :( Or is 64-bits an absolute nightmare for QNX?
> > OSTech
> cburgess@qnx.com
is 64-bit. :( Or is 64-bits an absolute nightmare for QNX?
We've only done 32-bit so far. The code is supposed to handle 64 bits,
but until you've done it the first time, you know there are going to be
places that need tweaking. Doing a 64 bit version is something that we
plan to do eventually - it's always the next thing up until something
more important comes along :-).
	Brian
Fair enough. I guess I will just shoot for LP64, and if some enormous wall
appears I can drop back to a 32-bit world. It sounds like there's nothing
too bad hiding in there, though.
> 	Brian
> http://community.qnx.com/sf/go/post15310
