sched_priority and priority inheritance
10/10/2008 3:23 PM
post14881
Here's an excerpt from the docs for the sched_param structure that is returned when you attempt to find your priority
using the pthread_getschedparam() call:
sched_priority
When you get the scheduling parameters, this member reflects the priority that was assigned to the thread or process
. It doesn't reflect any temporary adjustments due to priority inheritance.
If you examine a server thread after it has received a message, you'll see that this member *does* change to match the
client prio. Why is this? It seems to contradict the docs, and well as to be counter-intuitive. I would have guessed
that this member should stay the same, and the sched_curpriority member should change.
--Chris
