Forum Topic - coredumps with multithreaded processes: (6 Items)
I have 3 processes running on 6.3.2 with the libc.so.2 patch (patch-632-1125-632libc-sigqfix) on a x86 core 2 duo box.
One of the processes is a resource mgr.  I am compiling with 3.3.5
One of the 3 processes crashes after a few minutes of running.  Examining the coredumps almost always shows the
offending code in "free" (called from "delete" c++ app).  Occaisionally the coredumps aren't usable.
I have removed all the C++ stl library calls such as std::auto_ptr and std::string that I can (they seemed to be the
area of the crash).
I still haven't tracked down the problem, but I am beginning to suspect there may be a heap problem.
Has anyone seen a problem like this or have any suggestions on how to track down the problem?
Thanx
Tim
Re: coredumps with multithreaded processes
You can use QNX IDE Memory Analysis tool that specifically designed to find heap problems. You can also use command line
 version of it. You should be able to find docs about it online.
area of the crash).
> Thanx
> Tim
> http://community.qnx.com/sf/go/post12563
Attachment: Text elaskavaia.vcf 116 bytes
Thanx
The Memory Analysis tool running from the IDE freezes the remote QNX system (I am windows hosted).
Here is what I'm doing to test.  I have a resource mgr which does not have any hardware device.  It is a error logging
component which holds a stl deque in memory.  It is multithreaded.  I have an additional thread in that component which
takes the errors from the stl deque and writes them to a database.
The stl deque is protected with a mutex.  The additional thread which updates the database blocks on a conditional
variable until an error is logged.
I have a very simple multithreaded test program which just writes error messages to the logging component.  When I run
these two without the memory analysis, the event logging component crashes on a memory access of some type.  The
specific access is random, but it is always on a memory allocation, deletion or simple read.
When I run the memory analysis from the IDE the keyboard on the remote QNX machine freezes until I stop the debugger
from the IDE.
Any help would be greatly appreciated!  Thanx
Tim
P.S. I'm running 6.3.2 on a multi core CPU.
You should not run it in Debbugging session, try to launch it as Run launch configuration.
