Forum Topic - How to find ocb after iofunc_open_default ?: (4 Items)
Below is a snippet from resource manager tutorial.  How do I point to newly created ocb in the place indicated by a
comment? I extended ocb structure and I need to initialize my extra fields there.
int
io_open (resmgr_context_t *ctp, io_open_t *msg,
         RESMGR_HANDLE_T *handle, void *extra)
    int     sts;
    sts = iofunc_open_default (ctp, msg, handle, extra);
    if (sts == EOK) {
//HOW TO POINT TO OCB HERE?
        log_open_request (ctp, msg);
    return (sts);
RobertL
Re: How to find ocb after iofunc_open_default ?
You can use the (not documented in the current release)
   void *resmgr_ocb(resmgr_context_t *ctp)
call.
This may not exist in your libc, and you may have to instead use:
   void *_resmgr_ocb(resmgr_context_t *ctp,  struct _msg_info *info)
which is documented, but isn't quite as handy since it takes a few more
arguments.
Thomas
> created ocb in the place indicated by a comment? I extended ocb structure
> int
>    int     sts;
>    if (sts == EOK) {
>    return (sts);
> RobertL
> http://community.qnx.com/sf/go/post11405
Thank you, you are very helpful as always. In the mean time I had to do something, so I initialized my extra fields as
recommended in overrided ocb_calloc(), but it was not convenient at all. I had to pass some arguments via global
variables under mutex guard since I do multithreading there. Next time I touch this code I try your way.
> call.
RobertL
I could not resist temptation and I have rewritten this piece first time at work. resmgr_ocb() exists in my 6.3.0 sp3
and seems to work fine. Once again Thank You!
RobertL
