Forum Topic - getaddrinfo fails unexpected with Invalid argument at runtime: (2 Items)
The program in question is an unmodified example from the boost asio library:
http://www.boost.org/doc/libs/1_35_0/doc/html/boost_asio/example/http/client/sync_client.cpp
The problem is with getaddrinfo failing with the error message translated to Invalid argument. When debugging the error
code is 3/EAI_BADFLAGS.
Here two getaddrinfo hints that are NOT working (the first one is the default of the ASIO library):
{ai_flags = 0x400, ai_family = 2, ai_socktype = 1, ai_protocol = 6, ai_addrlen = 0, ai_canonname = 0x0, ai_addr = 0x0,
ai_next = 0x0}
{ai_flags = 0x400, ai_family = 0, ai_socktype = 1, ai_protocol = 6, ai_addrlen = 0, ai_canonname = 0x0, ai_addr = 0x0,
ai_next = 0x0}
but these ARE working:
{ai_flags = 1, ai_family = 0, ai_socktype = 1, ai_protocol = 6, ai_addrlen = 0, ai_canonname = 0x0, ai_addr = 0x0,
ai_next = 0x0}
{ai_flags = 0, ai_family = 0, ai_socktype = 1, ai_protocol = 6, ai_addrlen = 0, ai_canonname = 0x0, ai_addr = 0x0,
ai_next = 0x0}
0x400 is AI_ADDRCONFIG as defined in:
netdb.h:#define AI_ADDRCONFIG   0x00000400 /* only if any address is assigned */
My question is now: Where should the problem be fixed? Change the default in the lib especially for QNX (then to which
value)? Or is this a legal (so far undocumented) use of getaddinfo and will be fixed in QNX?
I'm compiling on Windows using QNX 6.3.0 SP3, but the runtime is QNX 6.3.2.
Thanks in advance
Christian
Re: getaddrinfo fails unexpected with Invalid argument at runtime
error code is 3/EAI_BADFLAGS.
 ai_next = 0x0}
 ai_next = 0x0}
ai_next = 0x0}
ai_next = 0x0}
> Thanks in advance
> Christian
AI_ALL, AI_V4MAPPED_CFG, AI_ADDRCONFIG, AI_V4MAPPED, AI_DEFAULT
were never supported and have been removed.  This fix will show
up in 6.4.
