Forum Topic - Memory fault in resource manager: (4 Items)
In multithreaded resource manager example from neutrino programmers guide I try to write to global char  string from
io_read function. This produces memory fault. How can I have  not only read, bul also write access to global variables
in io_xxx procedures attached in res mgr?
Souce attached. This is only an example to illustrate my problem, I am not just curious about writing 'X' to some char
string :)
RobertL
Attachment: Text rmmtrw.c 5.75 KB
AW: Memory fault in resource manager
Hi Bob,
this has nothing to do with resmgr issues. You are trying to modify the
contents of a constant string literal. Bad, Bad, boy!
In your code, you declare a pointer to char and initialize it to point
to a constant string:
 17  char *buffer = "Hello world\n";
That's ok. Well - not really. IMHO, if you tried compiling with all
warnings
on, the compiler should tell you 'warning: initialization discards
qualifiers
from pointer target type', because the literal on the right is constant,
while
the target of your pointer is not. The strange thing is: The compiler
doesn't
warn. Any compiler gurus around? Is this a bug or a feature?
Anyway, with the string literal being implicitly treated as 'constant',
it
ends up in the ".rodata" (read-only-data) section of your executable and
resides in a memory portion that is mapped read-only, i.e., any
attempted
write-access will cause a memory fault, thus enforcing the constantness
of
your constant strings.
To avoid this, you could e.g. replace the  '*buffer=""' by
   char buffer[] = "Hello world\n";
That way, you'd get an initialized array (just large enough for the
initial
string) that will actually be writable.
- Thomas
> -----Ursprungliche Nachricht-----
> Von: bob lipka [mailto:bobik@os.pl]
> Gesendet: 14 July 2008 12:19
> An: ostech-core_os
> Betreff: Memory fault in resource manager
> not only read, bul also write access to global variables in
> string :)
> RobertL
> http://community.qnx.com/sf/go/post10447
Re: AW: Memory fault in resource manager
Thank you, you are very helpful. Some other compilers I use are not so proper so I obviously have developed to many bad
habits...
AW: AW: Memory fault in resource manager
Don't feel too bad about it.
C, I think, is one of the best languages to develop some /really/
bad habits... which makes me like it so much....  =8-)
- thomas
> Gesendet: 14 July 2008 13:34
> An: ostech-core_os
> Betreff: Re: AW: Memory fault in resource manager
> 'constant',
> are not so proper so I obviously have developed to many bad habits...
> http://community.qnx.com/sf/go/post10449
