Re: QNX 8.0.4 x86_64 platform "Haswell" system timer delay
05/01/2026 6:17 PM
post122715
Stephen, here you go :
non UEFI or UEFI+CSM boot
Hypervisor support disabled
Added /memory/lapic
pci_find_class() returned D31:F0
Added 1 IOAPIC from ACPI tables
Base CPU interrupt for APIC is 48
lapic_configure(cpu=0), lapic_id: 0x00000000
Intel IOAPIC config
Found 1 IOAPIC's.
configuring IOAPIC id:8
Autofill: 16 of requested 40 entries available for profile 6
Restored IOAPIC B:D:F to 0:31:0 from 240:31:0
IOAPIC 8: successfully configured 40 vectors from 0 to 39
MSI interrupt = 0x00000100
MSI vector no = 94 0x0000005e
MSI vec count = 161
CPU Family/Model: 0x00000006/0x00000045
MSR_PLATFORM_INFO: 0x000803df3011900, TSC multiplier: 25
LAPIC on CPU 0 (ID=0x00000000) selected for system clock on IRQ 0x00010000
**Checking smp_hwcoreid for cpu 0
found ACPI reset reg addr/value of 00000000000cf9/00000006
using reset reg addr/value of 00000000000cf9/00000006
Loading IFS...decompressing...done
apic_smp_start(1), CPU 0, cep->smp_hwcoreid = 0x00000000
apic_smp_start(1), CPU 1, cep->smp_hwcoreid = 0x00000002
apic_smp_start(1), CPU 2, cep->smp_hwcoreid = 0x00000001
apic_smp_start(1), CPU 3, cep->smp_hwcoreid = 0x00000003
No low memory for AP start-up; using bootloader
apstart_init(0000000000000680, 00000000004018c43) [size=0x000000b6]
**Checking smp_hwcoreid for cpu 1
lapic_configure(cpu=1), lapic_id: 0x00000002
**Checking smp_hwcoreid for cpu 2
lapic_configure(cpu=2), lapic_id: 0x00000001
**Checking smp_hwcoreid for cpu 3
lapic_configure(cpu=3), lapic_id: 0x00000003
System page at phys:00000000001c000 user:fffff808000003000 kern:fffff808000007000
Starting next program at vffff80800004609e
overriding mask for controller 2, vector_base 0
Exar's devc-xrserpcie QNX-module ver 0.2 - x86_64-bits
16 Exar ports found.
