RPi4+screen with two displays
01/27/2024 1:31 PM
post122467
I see in the release notes that the driver seems to support two outputs and I see the firmware loaded (the gradient
colored square) if I plug two in. Any pointers for setting up the config file to support two pipelines? I'm just
trying to see gles2-gears appear on the second display (using the -display= option).
And if anyone could verify if the eglSwapBuffers() actually waits for the vertical sync (or if screen_wait_vsync() works
on the RPi), I'd be most appreciative. Trying to get good timing on display refreshes, but can't quite get that
working.
Thanks!
