Forum Topic - Failed dd clone of compact flash:
I tried using dd to clone the compact flash
dd if=dev/sda  of=/image.img  # copy original compact flash to a file
dd if=/image.img if=dev/sda    #copy file to target compact flash
but when I use the cloned compact flash I get an error that it can't read(?) the mounted drive:
mount -tgnx6 /dev/hd0t179 /d0
  mount: can't mount /d0 (type qnx6)
  mount: possible reason: read only file system.
What am I missing when making the clone?
Re: Failed dd clone of compact flash
clarification on the cloning process.  The cloning was done a different computer.   It was done on a computer running
RHE 8.  This way the compact flash cards are not "in use".
Is it at typing error or did you really use “if=" twice when writing back to the device?
Sent from my BlackBerry — the most secure mobile device
Sent: 14 January 2022 20:00
To: ostech-core_os@community.qnx.com
Reply to: ostech-core_os@community.qnx.com
Subject: Failed dd clone of compact flash
dd if=dev/sda  of=/image.img<http://image.img>;  # copy original compact flash to a file
dd if=/image.img<http://image.img>; if=dev/sda    #copy file to target compact flash
OSTech
http://community.qnx.com/sf/go/post121675
To cancel your subscription to this discussion, please e-mail ostech-core_os-unsubscribe@community.qnx.com<mailto:ostech
-core_os-unsubscribe@community.qnx.com>;
Attachment: HTML sf-attachment-mime40311 2.97 KB
Sorry, you are right, I did a typo.  It should be:
dd if=/image.ing of=/dev/sda
> the mounted drive:
I'm not sure if this will help but when I get this message it is invariably when using a QNX6 file system on a USB drive
. I don't know is a similar approach needs to be taken with your flash drive. I have used compact flash with QNX6
however with no such problems.
The way I fixed it (in QNX7) was by mounting as follows:
mount -t qnx6 -o sync=ignore /dev/usb0t177 /usb    (for example)
This allows me to write to the USB drive. Otherwise it's read only.
I imagine something like this might work for you:
mount -t qnx6 -o sync=ignore   /dev/hd0t179   /d0
