Forum Topic - RPi4 Support for eMMC?:
I've been successfully using the BSP 7.1 for a Model 4B, and recently have been exploring the compute module and its IO
Board.  I have a CM with eMMC and after setting up the eMMC and mounting as an external partition, I can get the system
up and running, and it seems to work as expected.  I'd be very interested to get the CM eMMC mounted after the machine
is up, and I suspect that some combination of options to devb-sdmmc-bcm2711 could work (but I could be completely wrong
about that!).  Is this possible, and if so, does anyone have pointers for options to pass to get the eMMC seen by QNX?
Re: RPi4 Support for eMMC?
After looking around a bit it seems to me that there is no eMMC on the RPi4. Pity...
No RTC either (lame excuse as to why not is given). A pity about that also - I have to resort to to an I2C module. The
provision of the I2C and SPI drivers with the BSP is very much appreciated!  Hopefully I can figure out how to use them!
Geoff.
> No RTC either
What do you mean by that?
--Elad
> > No RTC either
> --Elad
Real Time Clock. Battery backed that is.
Apparently they wanted to save on expense and space taking the view that RPi's will be connected to the internet where
they can obtain time from somewhere else. Otherwise enter it manually.
There are various I2C (and probably SPI) battery backed RTC modules available so I have ordered a couple in to play with
I'm not too cut up though. The Xilinx MPSoC's don't have one either and the ZCU102 is about 50 times the price of an
RPi4. So I was going to have to address this deficiency anyway.
Sorry, I was confused. I thought you meant a lack of support in the QNX BSP for a RTC, but now that I read your message
again you are talking about the hardware.
Yes, whatever add-on you get should work with SPI/I2C/GPIO, I would assume. There is also PCI, but it seems only to be
able to service the XHCI module.
--Elad
> been exploring the compute module and its IO Board.  I have a CM with eMMC and
> the system up and running, and it seems to work as expected.  I'd be very
> interested to get the CM eMMC mounted after the machine is up, and I suspect
>  be completely wrong about that!).  Is this possible, and if so, does anyone
I just discovered (yesterday) that there is a flavour of RPi4 called the "Compute Module 4". It has both eMMC and RTC
installed so David's question makes sense to me now.
I don't have one (yet). I am expecting RTCC (I2C) modules to arrive next week for the plain vanilla RPi4's I have that
use the DS3231 chip for which I will write a suitable RTC utility that acts like the QNX rtc utility. Hopefully the CM4
uses the same chip. I already did one for the Xilinx board using i2c (using the I2C PMOD) that works pretty well. But
different chip. Always fun!
I am now also keen to see if eMMC will work.
Geoff.
Has anyone managed to get the RPi Compute Module 4 (CM4) working with eMMC, or the CM4 Lite working with SDMMC?  If so,
what's the trick?
With the CM4 Lite (that has no eMMC but SDMMC on the I/O board instead) when I get to run the SDMMC driver (from the
normal IFS) it can't find the SDMMC hardware. But it's fine with a common RPi4. Has the SDMMC address changed with these
 CM4 boards?
It's interesting that the CM4 can start up with the ifs-rpi4.bin I normally use and establish a shell on /dev/ser1 (as
normal). So it can obviously see the SDMMC at this stage. But I simply can't run the SDMMC driver without it complaining
 about the lack of SDMMC hardware. Which means I can't mount a QNX6 filesystem (no /dev/sd0 or partitions).
Any help appreciated.
Geoff.
I don't have a compute module, and you may want to ask the question on the RPi forums.
However, the fact that it runs the IFS from the SD card doesn't mean that the QNX OS can see the card - the IFS is
copied from the card to memory by the RPI's firmware. The board may or may not have ful support for SD cards (in theory
it just needs the bare minimum to read a FAT partition).
--Elad
