Forum Topic - Can not connect to the QNX target for debugging:
Hello QNX,
I am now using Momentics under Windows.
Windows IP :192.168.14.9
Then I have the QNX running on the target at 192.168.14.11:21
Then the FTP connection was established between Host and Target, can also send files between host and target from both
sides.
But if I ping from Host : ping 192.168.14.9 working
if I ping from Target: ping 192.168.14.11 not working
Then I tried to connect the target for debugging, firstly run qconn command on the target
Then moentics always says that 192.168.14.11 not connected.
Do you have any ideas?
Tao
