Forum Topic - std::cout doesn't print letters after \n:
The following code always outputs:
Item1
Item2
Code:
#include <iostream>
#include <string>
int main() {
  std::string string_test{"Item1\nItem2\nItem3"};
  std::cout << string_test;
  return 0;
 Any explanations? Is this a bug?
Re: std::cout doesn't print letters after \n
at a guess, it's not flushing stdout because Item3 isn't followed by a '\n'. Try adding one and see whether that helps.
(I'm also guessing that you're showing just an excerpt of the actual code that's proving troublesome .. )
regards ..
Item1
Item2
Code:
#include <iostream>
#include <string>
int main() {
  return 0;
OSTech
http://community.qnx.com/sf/go/post119454
To cancel your subscription to this discussion, please e-mail ostech-core_os-unsubscribe@community.qnx.com<mailto:ostech
-core_os-unsubscribe@community.qnx.com>;
Attachment: HTML sf-attachment-mime37442 1.26 KB
Thank you Michael for the reply.
I tried flushing but without result. ( Surprisingly std::cerr works just fine even without flush)
Of course there are other ways to print, but the point here is that if this is a bug, we want to report to QNX.
BR,
Ilyas
What version of QNX are you using? There is a known bug in the handling
of line-buffered stream output in 7.0.3 only, that will be fixed in
7.0.4.
--Elad
> BR,
> Ilyas
> http://community.qnx.com/sf/go/post119456
Hi Elad,
Thanks for the information. Yes, I am using QNX 7.0.3.
BR,
Ilyas
