Forum Topic - QNX 6.6.0 on Intel based CPU with SDD drive and Power-Safe filesystem :
I have a SDD drive formatted with partition 179 and mounted as a /tmp directory.
The slogger  -c -s 200k -l /tmp/syslog,4096k   is running fine most of the time and creates /tmp/syslog1 and /tmp/
syslog2 files.
One a while i can notice that the content (size and time stamp) are are changing.
So i went to the  /tmp/directory and deleted syslog2 file (rm syslog2) and just to verify that the file is deleted run
ls command
TO MY BIG surprise the file still exist , it had different time stamp and the size was nearly 4MB. The content of that
file  (sloginfo /tmp/syslog2)  made  a sense .
Why the "rm"  command created such a condition on the file system. Should i worry about  the whole file system integrity
Any comments or explanation would be greatly appreciate specially from QNX .
Janusz
Re: QNX 6.6.0 on Intel based CPU with SDD drive and Power-Safe filesystem
Welcome to the wonderful world of union file systems!
You probably have a /tmp (typically a link to /dev/shmem) before
mounting the file system, which then puts its own /tmp directory on top
of the previous one. That previous directory is still there, and any
open file descriptors still point to files under it. When you deleted
the /tmp directory from the file system you re-exposed the /tmp
directory under it.
--Elad
> directory.
> of the time and creates /tmp/syslog1 and /tmp/syslog2 files.
> are changing.
> syslog2) and just to verify that the file is deleted run ls command
> and the size was nearly 4MB. The content of that file  (sloginfo
> Should i worry about  the whole file system integrity?
> from QNX .
> Regards,
> Janusz
> http://community.qnx.com/sf/go/post119100
> To cancel your subscription to this discussion, please e-mail ostech-
> core_os-unsubscribe@community.qnx.com
RE: QNX 6.6.0 on Intel based CPU with SDD drive and Power-Safe filesystem
Hi Elad,
     You made a great point but in my case the /tmp directory is mounted to the separate physical SDD drive  /dev/
hd1t179 remaining directories are mounted from /dev/hd0t179 which also is a SDD drive.
Janusz
Sent: Friday, September 14, 2018 1:58 PM
To: ostech-core_os@community.qnx.com
Subject: Re: QNX 6.6.0 on Intel based CPU with SDD drive and Power-Safe filesystem
You probably have a /tmp (typically a link to /dev/shmem) before mounting the file system, which then puts its own /tmp
directory on top of the previous one. That previous directory is still there, and any open file descriptors still point
to files under it. When you deleted the /tmp directory from the file system you re-exposed the /tmp directory under it.
--Elad
> directory.
> are changing.
> syslog2) and just to verify that the file is deleted run ls command TO
> Should i worry about  the whole file system integrity? Any comments or
> Regards,
> Janusz
> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fcommun
> ity.qnx.com%2Fsf%2Fgo%2Fpost119100&data=02%7C01%7Cjruszel%40lumine
> xcorp.com%7Cc0eeaf61c0a745f58c5608d61a740752%7Ce25a731e35c343c690c466b
> 856e6dd25%7C1%7C0%7C636725482985743814&sdata=I1MQQJr4FyDjX1AvIKo9C
> ta8TPw%2F0D3cJppTj9rinlU%3D&reserved=0
OSTech
https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fcommunity.qnx.com%2Fsf%2Fgo%2Fpost119101&data=02%7C01%
7Cjruszel%40luminexcorp.com%7Cc0eeaf61c0a745f58c5608d61a740752%7Ce25a731e35c343c690c466b856e6dd25%7C1%7C0%
7C636725482985743814&sdata=NByvPTeGhzT2PXd09lpcDJb%2FOftVIQv3R3SDUrSTCow%3D&reserved=0
That doesn't matter. The question is whether you have a /tmp directory
before you mount the file system on the SDD drive.
On Fri, 2018-09-14 at 19:05 +0000, Janusz Ruszel wrote:
> Hi Elad,
> mounted to the separate physical SDD drive  /dev/hd1t179 remaining
> Thanks,
> Janusz
> From: Elad Lahav <community-noreply@qnx.com>
> Safe filesystem
> any open file descriptors still point to files under it. When you
> --Elad
> > /tmp
> > directory.
> > of
> > are
> > are changing.
> > TO
> > and
> > or
> > Regards,
> > Janusz
> > OSTech
> > mun
> > ine
> > 66b
> > o9C
> > ostech-
> nity.qnx.com%2Fsf%2Fgo%2Fpost119101&data=02%7C01%7Cjruszel%40lumi
> 66b856e6dd25%7C1%7C0%7C636725482985743814&sdata=NByvPTeGhzT2PXd09
> http://community.qnx.com/sf/go/post119103
Agree!
