Forum Topic - QNX SCHED_IDLE ?:
QNX SCHED_IDLE ?
Hi all,
I am trying to run some tasks on a system "in the background", that is, not stealing any cycles while the system is busy
, only running when the CPU would be IDLE otherwise.
Is there some way to get a similar behaviour in QNX like for SCHED_IDLE in Linux?
Maybe this could be recreated with some other scheduling class?
Thanks a lot for any advice,
Claudio
Re: QNX SCHED_IDLE ?
In Qnx You have up to 256 priority levels: just assign a low priority  (Es.1..10) to
your 'background' processes. 0 is the priority of idle process.
Mario
Running at priority 1 will do what you want logically, but expect the target to run "much hotter".
The "idle thread" is not truly a thread - idle state puts the processor in a "wait for interrupt" mode which is requires
 relatively little power.  The time spent in that mode is charged to idle thread 0.
You may want to look at the InterruptHookIdle function.
Al
Please don't ;-)
That function is for power management. It is called in a very
restrictive environment and needs to adhere to a strict protocol
(similar to an ISR, but with even more ways of screwing things up).
What Claudio is looking for, as far as I can tell, is a way to run some
tasks when nothing else is scheduled. A priority 1 thread in a regular
process will do just fine...
--Elad
> Regards,
> Al
> http://community.qnx.com/sf/go/post119086
> To cancel your subscription to this discussion, please e-mail ostech-
> core_os-unsubscribe@community.qnx.com
thanks all for your comments,
I will do some experiments based on your suggestions  :-)
