Forum Topic - how to run a prebuilt app on QNX?:
Hi QNX,
I have bootup QNX on target board from SD card, and there is also a prebuilt/cross-compiled application executable on SD
 card. Then I mounted SD card to filesystem by following commands,
     mount -t dos /dev/hd0t11 /sd
     cd /sd
     chmod 777 myapp
     ls -al
        -rw-rw-rw-  1 root      0             25633 Mar 05  2018 myapp
chmod is not able to change the mode, and myapp is still not runnable.
Please advise, thanks in advance
Mike
Re: how to run a prebuilt app on QNX?
this is because the DOS FAT file system has no UNIX-like permissions. Try
   mount -t dos -oexe=all /dev/hd0t11 /sd
That should set the x bits on all files on your sd card. See fs-dos.so docs for more options...
Cheers,
Thomas
An alternate way is to put "dos exe=all" on the startup line of the devb-* resource manager.  For example,
# devb-eide dos exe=all qnx6 sync=optional cam quiet
BSP's seem to favor this approach - perhaps because it works with "automount".  But both ways work.
RE: how to run a prebuilt app on QNX?
Needless to say (but I'll say it), both of these options are highly insecure, essentially making the execute bit useless
 (as it gets applied to all files on the medium).
If you don't have a disk with a file system that provides proper permissions (and user/group ownership) you can always
copy the executable to /dev/shmem and run it from there.
--Elad
Sent: March 5, 2018 8:16 AM
To: ostech-core_os
Subject: Re: how to run a prebuilt app on QNX?
OSTech
http://community.qnx.com/sf/go/post118647
Re: RE: how to run a prebuilt app on QNX?
Also, if you want to avoid all files being executable, there is
   exe=system
— use the DOS “system” attribute to indicate which files are executable.
Execute bits don’t really affect security at all, at best they prevent you from accidently executing things that likely
 won’t execute anyway.  In this case there likely is no security but that’s a function of having an unverifiable file
system.
useless (as it gets applied to all files on the medium).
always copy the executable to /dev/shmem and run it from there.
    --Elad
    To: ostech-core_os
Thank you all QNX experts. I have learned a lot.
Best
