interpreting the output of showmem vs pidin
10/05/2017 7:04 PM
post118092
I have a process called 'astro' that appears to be using more memory than expected. Using pidin, I can see this:
# pidin -f mbh -p astro
stack tid thread name
32K(516K)* 1 ASTRO
8192(132K) 2 conman_thread
4096(132K) 3 _WatchdogThread
12K(132K) 4 _NucleoThread
8192(132K) 5 /AstroServer
Which is pretty clear. However, I also wanted some heap information, so I run showmem, which unfortunately cannot be
filtered by process other than grep (?)
# showmem -Dsh | grep -n astro
184: 1441792 401408 471040 430080 118784 20480 385064 astro
185: 0 0 0 0 12288 0 385064 astro (thread 4)
186: 0 0 0 0 49152 0 385064 astro (thread 4)
187: 0 0 0 0 8192 0 385064 astro (thread 5)
188: 0 0 0 0 4096 0 385064 astro (thread 4)
189: 0 0 0 0 8192 0 385064 astro (thread 2)
190: 0 0 0 0 32768 0 385064 astro (thread 1)
191: 0 0 0 0 4096 0 385064 astro (thread 3)
Now I got confused:
1) Why does thread 4 show up 3 times, with different stack sizes. I used grep -n so you see the line numbers; these
are not in different sections of the showmem output, and have the same pid.
2) How does pidin show a total heap of 12k for thread 4, but showmem shows another thread 4 with 49k ?
3) the threads show 0 heap. Is that always the case, it being shared ?
I've read through the showmem docs a few times, but I haven't found anything that explains what I am seeing.
