Re: 6.6 Installer error /tmp/install.dir.6724/Linux/resource/jre/bin/java: not found
09/22/2017 6:44 AM
post118071
to reply to myself, this is what I found on askubuntu.com
Once you install the 32-bit dynamic loader /lib/ld-linux.so.2, which is in the libc6:i386 package, you will at least get
a non-misleading error message telling you of the other missing libraries.
HTH
Michael
On Free, 2017-09-22 at 12:15 +0200, Michael Schuster wrote:
I managed to reproduce this error in a freshly installed Ubuntu 16.04.3 server image in VMWare;
I dug a little further:
$ ./qnx-sdp-6.6-201402230339.bin
Preparing to install...
Extracting the JRE from the installer archive...
Unpacking the JRE...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
./qnx-sdp-6.6-201402230339.bin: 3320: exec: /tmp/install.dir.3916/Linux/resource/jre/bin/java: not found
(the same happens when I use sudo)
$ file /tmp/install.dir.3916/Linux/resource/jre/bin/java
/tmp/install.dir.3916/Linux/resource/jre/bin/java: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically
linked, interpreter /lib/ld-linux.so.2, for GNU/Linux 2.2.5, not stripped
when we look at 'file' output, we see "interpreter /lib/ld-linux.so.2", but:
$ ll /lib/ld-linux.so.2
ls: cannot access '/lib/ld-linux.so.2': No such file or directory
on my "normal" linux workstation, this looks different:
$ ll /lib/ld-linux.so.*
lrwxrwxrwx 1 root root 25 Jun 16 22:36 /lib/ld-linux.so.2 -> i386-linux-gnu/ld-2.23.so*
I didn't find a trivial way to install this link (nor its target), but this looks like a system setup issue to me.
regards
Michael
On Dunn, 2017-09-21 at 15:56 -0400, David Lypka wrote:
Thanks for the suggestion but no luck - all folders in the path are r-x for everyone else.
I also tried it on and old ubuntu 12.04 in Virtual Box and still got the same error.
So both 16.04 and 12.04 have the problem accessing java.
So perhaps the error message is just an unwanted side effect of the actual cause.
I searched for all .log files and looked at a few but did not find anything related to the is QNX install.
Do you have any other suggestions?
OSTech
http://community.qnx.com/sf/go/post118064
To cancel your subscription to this discussion, please e-mail ostech-core_os-unsubscribe@community.qnx.com<mailto:ostech
-core_os-unsubscribe@community.qnx.com>
