Forum Topic - PPS Subscription - Non Blocking Read behavior:
We are using PPS to interface with QNX Wireless Framework. We prefer using the default non blocking behavior for PPS
subscription. According to PPS manual ( Excerpt below ) it preferable to set FD to blocking. What are the ramifications
of using non blocking fd's here?
--------------  QNX PPS manual - Page 30---- --------------------------------
--Blocking and nonblocking reads--
Reads to PPS objects are nonblocking by default, but the preferred method for querying PPS objects is to use blocking
reads.By default, reads to PPS objects are nonblocking; that is, PPS defaults a normal open()
to O_NONBLOCK, so that reads made by the client that opened the object don't block.
The PPS default behavior when it reads is atypical for most filesystems. It's done this way so that standard utilities
won't hang waiting for a change when they make a read() call on a file.For example, with the default behavior, you could
 tar up the entire state of PPS using the standard tar utility. Without this default behavior, however, tar would never
make it past the first file opened and read.
Setting PPS to block
Though the PPS default is to open objects for nonblocking reads, the preferred method for querying PPS objects is to use
 blocking reads. With this method, a read waits until the object or its attributes change, then returns data.
To have reads block, you need to open the object with the ?wait pathname open option, appended as a suffix to the
pathname for the object. (For more information on the ?wait option, see Pathname open options (p. 40).)
For example:
• to open the PlayList object for the default nonblocking reads, use the pathname:"/pps/media/PlayList"
• to open the PlayList for blocking reads, use the pathname plus the option: "/pps/media/PlayList?wait"
A typical loop in a subscriber would live in its own thread. For a subscriber that opened the object with the ?wait
option, this loop might do the following:
/* Assume that the object was opened with the ?wait option
No error checking in this example. */
for(;;) {
read(fd, buf, sizeof(buf)); // Read waits until the object changes
process(buf);
Clearing O_NONBLOCK
If you have opened an object without the ?wait option and want to change to blocking reads, you can clear the O_NONBLOCK
 bit, so that the subscriber waits for changes to an object or its attributes.
30 © 2014, QNX Software Systems Limited
Subscribing
To
clear the bit you can use the fcntl() function. For example:
flags = fcntl(fd, F_GETFL);
flags &= ~O_NONBLOCK;
fcntl(fd, F_SETFL, flags);
Or you can use the ioctl() function:
int i=0;
ioctl(fd,FIONBIO,&i);
After clearing the O_NONBLOCK bit, you can issue a read that waits until the object
changes.
Attachment: PDF QNX_Persistent_Publish_Subscribe_Developers_Guide.pdf 1.05 MB
Re: PPS Subscription - Non Blocking Read behavior
There is no reason not to use the default, non-blocking, behavior of PPS,
the documentation is a little is misleading saying blocking is preferred..
The only ramification is the usual impact of non-blocking fds namely that
you need to use select or ionotify to know when there is data to read but
that's it.  The first read from a regular PPS object will always return
its content irrespective of whether the object was opened blocking or
non-blocking, it's only subsequent reads that are affected.
On 2016-10-26, 1:47 AM, "Sesh" <community-noreply@qnx.com> wrote:
>Hello,
>using the default non blocking behavior for PPS subscription. According
>are the ramifications of using non blocking fd's here?
>for querying PPS objects is to use blocking reads.By default, reads to
>don't block.
>It's done this way so that standard utilities won't hang waiting for a
>default behavior, you could tar up the entire state of PPS using the
>never make it past the first file opened and read.
>preferred method for querying PPS objects is to use blocking reads. With
>returns data.
>open option, appended as a suffix to the pathname for the object. (For
>For example:
>€ to open the PlayList object for the default nonblocking reads, use the
>€ to open the PlayList for blocking reads, use the pathname plus the
>subscriber that opened the object with the ?wait option, this loop might
>do the following:
>for(;;) {
>process(buf);
>Clearing O_NONBLOCK
>to blocking reads, you can clear the O_NONBLOCK bit, so that the
>Subscribing
>To
>int i=0;
>the object
>changes.
>OSTech
>http://community.qnx.com/sf/go/post117011
>ostech-core_os-unsubscribe@community.qnx.com
Thanks Roger.
Our SW architecture has a built in polling mechanism to wake up subscriber threads periodically. Based on your
explanation it looks like we'll receive one or more messages during poll+read if publisher is active. I am not sure if
publisher data will be buffered with message boundaries or overwritten.
Sesh
The behavior depends on how you open a PPS object.  If you open an object
in full mode (the default), then irrespective of whether there has been a
single update or many, you'll just see the current, full contents of the
PPS object.  If you open the object in delta mode by appending "?delta" to
the name (or ",delta" if you've already some options) then the message
boundaries are preserved, you get to do one read for every write that has
been made and each read shows only the changed attributes.
My personal opinion is that it is usually better to use delta mode.
You can see the behavior of PPS by just using cat and echo on the command
line.
If in one terminal you run:
touch /pps/object
cat /pps/object?wait,delta
And then in another:
slay -s STOP cat
echo attrib1::1 >>/pps/object
echo attrib1::2 >>/pps/object
echo attrib1::3 >>/pps/object
echo attrib1::4 >>/pps/object
slay -s CONT cat
Then you can see all the reads that are queued up for the cat process by
preventing it from running, making a few updates and then resuming it.
You just have to ensure that you use 'wait' with cat or it exits as soon
as it has read the initial data.
On 2016-10-26, 2:29 PM, "Sesh" <community-noreply@qnx.com> wrote:
>Thanks Roger.
>subscriber threads periodically. Based on your explanation it looks like
>active. I am not sure if publisher data will be buffered with message
>Thanks,
>Sesh
>OSTech
>http://community.qnx.com/sf/go/post117013
