Forum Topic - memory mapped devc-ser8250: (3 Items)
HI
I am having to get working a versalogic VL-MPEe-U2 serial port. it is a minipcie quad serial card with XR17V354 UART.
This device is memory mapped , not i/o mapped.
in the last generic  BSP for x86 i found a devc-ser8250 that can work with io mapped devices, but only i can make work
the frst port.
if i type devc-ser8250 -m [address], [IRQ]
i get /dev/ser3 ( the board have 2 more integrated serial ports).
i tried it making a loopback and using qtalk. for some strange reason it only works to 9600. after that i receive
garbage.
when i try starting the other ports the driver hangs
devc-ser8250 -m -u3 [address],[IRQ]  -u4 [address+8 ],[IRQ] -u5 [address+16],[IRQ] -u6 [address+24],[IRQ]
Re: memory mapped devc-ser8250
I solved it looking at the datasheet for xr17v358
teh ofsset between ports is not 8 as i've seen on other boards, is 400 Now the card is working.
I have only the issue of the speed. it works ok until 9600. at faster speeds i get garbage
What's the interface clock to the controllers? The driver assumes the 8250's 1.843 MHz clock. Try setting the "-c clock[
/divisor]" argument to the driver with the appropriate value.
Anas
