08/19/2016 9:51 AM
post116669
I am working with an acromag xcom-6400 board with an acromag acex-4600 carrier.
QNX 6.5(not SP1) installed fine.
I have installed 2 PMC cards. a GE qpm-1553 card and a tewsTPMC-385 quad ethernet card.
When using a buildile with startup-bios and pci-bios the GE QPM-1553 runs fine, but QNX can't detect when the ethernet
cable os connected to the tews card, so i doesn't work. .
When using a buildifile with startup-apic and pci-bios-v2 the tews ethernet card works fine, but the ge QPM-1553 crashes
. also i loss the USB 3.0 ports
the last lines in the sloginfo shows when the ge card crashes.
The acromag is PCI express, so for the PMC it have a bridge PCIe to PCI.
the ethernet card is PMC, but internally have a bridge PCI to PCIe
The chipset in the ethernet card is a i82574L
When using startup-apic, if i run pci-bios after the computer has booted( pci-bios-v2 is already running) the GE QPM-
1553 works fine, but still the usb 3.0 ports are not present
