Forum Topic - pidin info reporting two processors on a single-core Atom processor:
We are running QNX 6.5.0 base release (not SR1) on an Intel Atom N455 processor.  Our image is using proctno-smp-instr.
 We are using the smp version because our software can run on a dual core VortexDX3 processor.
Pidin info reports the following on the Atom processor:
# pidin info
CPU:X86 Release:6.5.0  FreeMem:775Mb/1013Mb BootTime:Jan 01 00:00:05 UTC 2002
Processes: 29, Threads: 163
Processor1: 66222 Intel 686 F6M12S10 1668MHz FPU
Processor2: 66222 Intel 686 F6M12S10 1670MHz FPU
Tracelogger shows CPU #2 periodically switching between idle and ready, but never running.
1. Is this a known issue?
2. Are there any bad consequences running this way?
Re: pidin info reporting two processors on a single-core Atom processor
Do you have hyper threading enabled in your bios?
Jerry Sui | Software Developer | jsui@qnx.com
O:613-595-3758   C:613-240-9239 | www.qnx.com <http://www.qnx.com/>; | QNX
Software Systems
Cisco Support Team email: cisco_support@qnx.com
On 2016-05-25, 11:09 AM, "Robert Murrell" <community-noreply@qnx.com>
>processor.  Our image is using proctno-smp-instr.  We are using the smp
># pidin info
>2002
>but never running.
>OSTech
>http://community.qnx.com/sf/go/post116334
>ostech-core_os-unsubscribe@community.qnx.com
The unit is in a "Do not touch" test right now, but the board user guide says its on by default.  So almost certainly so
You should turn off it then.
Software Systems
On 2016-05-26, 12:59 PM, "Robert Murrell" <community-noreply@qnx.com>
>says its on by default.  So almost certainly so.
>OSTech
>http://community.qnx.com/sf/go/post116344
Is hyperthreading a problem with QNX 6.5.0?
It is not a problem with QNX 6.5.0, but qnx is not optimized for
hyperthreading. If the 2 threads are in different processes, there will be
a lot of context switch on the same physical CPU, which is not efficient.
Please see the following link for more information about hyper threading.
https://en.wikipedia.org/wiki/Hyper-threading
Thanks.
Software Systems
>OSTech
>http://community.qnx.com/sf/go/post116348
