Forum Topic - The 'at' command for QNX:
Is there source code for the Linux 'at' command which will compile for QNX?  I have tried searching, but using the
letters AT for search criteria, even categorizing it fails to get me anything close.
Re: The 'at' command for QNX
You can look at cron / crontab
> http://community.qnx.com/sf/go/post115961
Thank you for the reply.
I need to run a command once after boot, delayed about 2 minutes.  Cron does not do this that I know of.
Something like:
on -d sh -c "sleep 120 && echo 'hello'"
> http://community.qnx.com/sf/go/post115963
Thank you.
Where might I find man pages for the 'on' command.  I could not find it in the docs I have been using.  Searching for
help on the 'on' command is as bad as the 'at' command  :)
Thank you.
