03/11/2016 9:31 AM
post115945
Hi Guys,
I have a problem with the UDP socket.
The code is following:
if ((sock_broadcast= socket(AF_INET, SOCK_DGRAM, 0)) < 00) {
printf("socket creation error\n");
//set broadcasting socket options
const int opt = 1;
extern int errno;
if (setsockopt(sock_broadcast, SOL_SOCKET, SO_REUSEPORT | SO_BROADCAST | SO_KEEPALIVE,
(char *) &opt, sizeof(opt)) < 0) {
printf("[set socket options error...%d\n", errno);
I create a UDP socket, then I use setsockopt() to set the options with REUSE and BROADCAST. It always returns -1, but
the errno number is 0.
Do you have any solution to this problem?
Thanks in advance.
Re: Problem with UDP Socket
03/11/2016 9:33 AM
post115946
You need to include <errno.h> and get rid of 'extern int errno'.
errno is special.
On Fri, Mar 11, 2016 at 09:31:11AM -0500, Long Peng wrote:
> Hi Guys,
> const int opt = 1;
> extern int errno;
> Thanks in advance.
> http://community.qnx.com/sf/go/post115945
03/11/2016 10:06 AM
post115947
Hi Sean,
Thanks for your response. Now I get the errno.
But Why does setsockopt() return error ENOPROTOOPT ? 242 /* Protocol not available */.
I try to bind the socket. I also return error EADDRNOTAVAIL 249 /* Can't assign requested address */.
The code is like this:
bzero(&addr_broadcast, sizeof(struct sockaddr_in));
addr_broadcast.sin_family = AF_INET;
addr_broadcast.sin_addr.s_addr = htonl(INADDR_BROADCAST);
addr_broadcast.sin_port = htons(SOCK_BROADCAST_PORT);
if (bind(sock_broadcast, (struct sockaddr *) &(addr_broadcast), sizeof(struct sockaddr_in)) < 0) {
printf("bind sock_broadcast error...%d\n", errno);
Do you have any opinion? I am wondering if QNX UDP supports broadcasting, or I dis something wrong.
best regards,
Long
> errno is special.
> > Hi Guys,
> > printf("socket
> creation error\n");
> > const int opt = 1;
> > extern int errno;
> SO_KEEPALIVE,
> , errno);
> and BROADCAST. It always returns -1, but the errno number is 0.
> > Thanks in advance.
> > OSTech
03/11/2016 10:08 AM
post115948
You can't or in options. They're not flags.
On Fri, Mar 11, 2016 at 10:06:05AM -0500, Long Peng wrote:
> Hi Sean,
> best regards,
> Long
> > errno is special.
> > > Hi Guys,
> > > printf("socket
> > creation error\n");
> > > const int opt = 1;
> > > extern int errno;
> > SO_KEEPALIVE,
> > , errno);
> > > Thanks in advance.
> > > OSTech
> http://community.qnx.com/sf/go/post115947
03/12/2016 7:11 AM
post115951
You are absolutely correct, Sean. There is no problem if I set the options one by one. They are not flags.
Thanks very much.
> > Hi Sean,
> errno);
> > best regards,
> > Long
> > > errno is special.
> > > > Hi Guys,
> > > > printf("
> socket
> > > creation error\n");
> > > > const int opt = 1;
> > > > extern int errno;
> > > SO_KEEPALIVE,
> ...%d\n"
> > > , errno);
> REUSE
> > > > Thanks in advance.
> > > > OSTech
> core_os
> > OSTech
