Re: RE: Mounting an EFS file?
04/07/2016 2:24 AM
post116065
Hi all,
I have the same problem. But the commands you gave don't worked for me.
In my case, I have a flash system distributed in two flash memory of 64 MB (GL512).
The command devf-ram and flashctl seemed to work perfectly, but not cp.
When I execute the command, It works again and again but there is no result.
Here is the commands I wrote :
# devf-ram -vvv -s0,128m,,,256k
# flashctl -p /dev/fs0 -ev
#cp -V /home/flash.bin /dev/fs0 <- this one don't work, flash.bin is my flash's dump, his size is precisely of 128MB.
I work with a QNX Virtual Machine (Neutrino) downloaded from QNX's website. I fixed the RAM size at 4GB.
I'm pretty stuck at this point, my other solution is to reconstruct the file system directly from the dump, but this
solution is more time consummer.
Thanks by advance for your responses.
Max
