Forum Topic - QT with composite windows: (10 Items)
I'm a QNX newbie on trial licenses evaluating QNX with QT for future applications for our company.
I've built a BSP and boot image, integrated QT, CAN and other drivers. I've written a small QT application driven by CAN
 messages from a PLC running CodeSys. So far so good.
I would like now to run several QT application windows as separate processes within different QNX screen composite
windows. My architectural aim is not to have a huge monolithic HMI, we also have the need to mix technologies other than
 QT.
I've read the documentation such as at
http://www.qnx.com/developers/docs/660/index.jsp?topic=%2Fcom.qnx.doc.screen%2Ftopic%2Fmanual%2Fcscreen_composition.html
I've also searched the QT forum but not turned up anything helpful.
and understand the principles. However, I have no idea how to implement this in practice e.g. how can a QWindow be
created separate as a separate window from the 'screen' processes.
I'm using SDP 6.6 with qnx-sdk-for-apps-and-media-1.1-201503251644 which I think contains pre-compile QT 5.3 libraries.
For hardware, I'm using Sabrelite board.
Any more detailed pointers or better code samples would be extremely helpful.
Nick Barton
RE: QT with composite windows
I don't entirely understand your question but I'll try to provide some information that might help.
Each QWindow is associated with a separate screen window.  If you have multiple Qt processes, each with a QWindow with
their x, y, width and height properties set so that they are not totally overlapping they should all show up on the
screen at the same time.  This might be enough if your needs are very simple i.e. you have a fixed layout of the screen.
If you require more than this you are likely to want a process to act as a window manager.  This will get events from
screen notifying it of the creation of top level windows from other processes and it can change positions, z-order,
displayed sizes and visibility of these windows.  With the current QNX Qt platform plugin it is not possible for a Qt
application to act as a window manager, or at least Qt provides nothing to help you with this (you'd have to create a
separate window manager screen context and monitor events from it in a separate thread).
We have developed a new QNX platform plugin for Qt which we are in the process of upstreaming to code.qt.io that
provides much better integration with screen including the ability for a Qt app to act as a window manager and the
ability to modify most or all screen window properties associated with a QWindow.
Sent: Wednesday, February 03, 2016 10:09 AM
To: ostech-core_os
Subject: QT with composite windows
 QT.
Nick Barton
OSTech
http://community.qnx.com/sf/go/post115664
Thanks for your email Roger
I don't think the first solution will be enough as it won't provide the ability to mix technologies i.e. QT apps, Open
EGL apps, HTML5 apps.
Also if I've understood you correctly, they won't be separate QNX processes but QT threads running QT Windows i.e. it
would still be a monolithic app. I'm trying to avoid that architecture as it is cumbersome to maintain, inflexible in
deployment to different product streams (we have many derivitave products that have more or less features), harder to
manage the processes i.e. mapping resources to a HMI process that implements safety function, also control via the High
Availability Module HAM.
When will the plugin you are working on be available?
From: Roger Maclean [mailto:community-noreply@qnx.com]
Sent: 03 February 2016 17:01
To: ostech-core_os@community.qnx.com
Subject: RE: QT with composite windows
To: ostech-core_os
 QT.
Nick Barton
OSTech
To cancel your subscription to this discussion, please e-mail...
No, what I was talking about doesn't require that everything be in one process or be solely Qt.
The simple case I mentioned allows any mixture of processes using any type rendering, Qt, OpenGL, HTML5.  It's just in
this case because there is no window manager the applications themselves are responsible for their own layout.  If the
set of windows display on the screen is fixed then this can work OK.  Each process arranges to create their window with
the appropriate size and positions it at the appropriate place and you're done.
Where this doesn't work is where things need to be more dynamic, especially if you're aiming for fancy effects.  If you
want to have windows come and go and change positions then it helps to have something central to do this which is where
window managers come into the picture.  If you're developing a product like a typical smartphone you need a window
manager, if it's something like a medical device which has a fixed set of windows in a fixed arrangement then you might
not.
A window manager can be a regular graphical application which has its own windows or it can do nothing but window
management.  The restriction about Qt apps acting as window managers is that to do anything in screen you have to create
 a screen context and their are two types of them, application contexts and window manager contexts and the current QNX
plugin creates a application context.  If you're writing a Qt app there is nothing to prevent you from creating a
separate window manager context it's just that Qt doesn't do anything much to help you.
I'm not sure when the new plugin will be available (I'm no longer working on Qt).  We are actively working on
upstreaming the code so the time depends partially on how long it takes to get the Qt community to accept it.  I've no
idea when QNX would provide binaries for it though once it has been upstreamed the source will be publically available.
 One complication with it is there are aspects of it that make use of new features of screen that have not yet been
released, they're not essential for most of the core functionality but they make it all a little harder.
Sent: Thursday, February 04, 2016 4:00 AM
displayed sizes and visibility of these...
Thanks Roger, got it.
The first case is just fine for us, multiple GUI processes talking to separate Screen windows, possibly different
technologies but mostly Qt processes and most importantly fixed layout of windows. The only important thing over this is
 for the windows to be able to be made visible or hidden depending on the state of the system.
Given that, have you got any code examples of how to achieve the above, particularly how to create a simple QT
application within a Screen window. Just need a starting point.
Nick
Sent: 04 February 2016 13:41
not.
To:...
You could try this as an example though no promises as to whether it actually works.  I'm not working on Qt just now and
 not in a position to try it out.  Hopefully it be of some use even if not quite right (and it's pretty trivial).
Sent: Thursday, February 04, 2016 9:00 AM
Nick
not.
deployment to different product streams (we have many derivitave...
Attachment: Text play.tgz 14.86 KB
That's great Roger,
Any help is welcome. I just need to get to a starting point upon which I can develop.
Regards
Nick
Sent: 05 February 2016 13:48
Nick
not.
I don't think the first solution will be enough as it won't provide the ability to...
Re: RE: QT with composite windows
Nick-  If you build your own Qt libraries, you "may" have to set this environment variable to keep the app from taking
the full screen.  (Building against Apps & Media Qt libraries does not require this!)
export QT_QPA_PLATFORM=qnx:no-fullscreen
Of course its hard to "share" the screen with multiple apps if one component covers it all.
RE: RE: QT with composite windows
Dennis
Thanks for the tip.
I have built Qt 5 but for the x86 integrated into Visual Studio.
I fully intend to build Qt 5 for ARM using the Momentics compiler but haven't done so yet.
Nick
From: Dennis Kellly [mailto:community-noreply@qnx.com]
Sent: 05 February 2016 15:11
To: ostech-core_os <ostech-core_os@community.qnx.com>
Subject: Re: RE: QT with composite windows
OSTech
http://community.qnx.com/sf/go/post115685
Thanks Dennis
All that was actually needed was to set export the environmental variable (which I added to my BSP build), then  set the
 Qt window size  and position and that worked. No need to re-compile the Qt libraries.
Thanks again
Nick
OSTech
