No space left on device - but there is !
05/07/2008 4:22 PM
post7838
I installed a clean M6 build on Vmware (winxp vm server 1.04) w. a 6GB disk using a partition type of 179 - the new
filesystm.
I then checked out the HEAD_640 pkgsrc - that's a whole lot of files.
Before it finished the complete checkout, svn failed with:
Can't open <some file> : No space left on device
A 'df' shows I'm only at 29% of disk usage, but there are a *lot* of files (maybe 200,000)checked out - is it likely
running out of something else e.g. inodes so the error message is not quite right ?
I deleted the HEAD dir and ran it again - same result, different file, but similar distance into checkout.
There's nothing useful in sloginfo.
I suspect the filesystem more than I do svn - any suggestions for something I might be doing wrong ?
Dave
