No routing of interrupts to PCI devices on PCIe system with startup-apic?
01/13/2015 11:00 AM
post112921
Hello experts,
I have the problem that we want to switch over to startup-apic from out startup-bios based system to avoid interrupt
sharing because a device creates a huge amount of interrupts periodically.
For this, we started up the system with startup-apic and pci-bios-v2. But now our drivers are not able to attach to the
device with pci_attach_device anymore, sloginfo states:
Bus X device Y - No routing found
last_chance on AA:BB:CC irq 11
Does anybody have an hint on what to do to enable the platform to complete the routing for the interrupts?
Thanks in advance,
Sven
Re: No routing of interrupts to PCI devices on PCIe system with startup-apic?
01/14/2015 5:08 PM
post112942
Hi Sven,
I don't know for sure if this is your problem, but I ran in to something similar a while back. Unfortunately the
current release of the QNX x86 BSP cannot route interrupts through PCI bridges that aren't documented in the routing
table by the BIOS. This includes all external PCI-to-PCI bridges, as well as any onboard PCI-to-PCI bridges that the
BIOS authors just didn't bother to explicitly document (usually because they follow the standard routing practice, and
additional information isn't necessary for other OSes).
If you know your device is behind a PCI-to-PCI bridge somewhere, I can send you a patch to the x86 BSP to work around
that particular issue. I've already sent it on to the folks at QNX some time back, but it is a bit of a hack and
they're busy people, so it's hard to know if or when this might make in to an official update.
Let me know,
-Will
01/15/2015 12:30 PM
post112955
Hi Will,
am Mittwoch, 14. Januar 2015, 17:08:39 schrieben Sie:
> similar a while back. Unfortunately the current release of the QNX x86 BSP
> routing table by the BIOS. This includes all external PCI-to-PCI bridges,
> as well as any onboard PCI-to-PCI bridges that the BIOS authors just didn't
> routing practice, and additional information isn't necessary for other
> OSes).
Thanks for the info!
> you a patch to the x86 BSP to work around that particular issue. I've
> hack and they're busy people, so it's hard to know if or when this might
That's exactly the case: We have a CompactPCI system which is coupled to the
CPU board via a PCI-to-PCI bridge. So your patch would be very welcome and I
will try it out if it helps in our system!
Thanks in advance,
Sven
Sven Fischer (Dipl.-Phys.) - EDV- und SAP-Beratung
Platzer Höhenweg 34, 51429 Bergisch Gladbach, Germany
Tel.: +49-(0)2204-9670010, Fax: +49-(0)2204-9670019
Mobil: +49-(0)172-2012493, Web: http://www.effeffcee.de
01/15/2015 2:52 PM
post112956
Hi Sven,
Here it is. Good luck!
-Will
01/15/2015 2:59 PM
post112957
Hello Will,
am Donnerstag, 15. Januar 2015, 14:52:51 schrieben Sie:
Thx a lot!
Regards, Sven
01/16/2015 3:20 PM
post112980
Hi Sven,
No problem. Please let me know if it works for you! We actually wrote it for the very same reason, to support a CPCI
host computer that used a bridge to connect the CPCI bus.
-Will
01/20/2015 7:12 AM
post113007
Hi Will,
Am 16.1.2015 21:20, schrieb Will Miles:
> wrote it for the very same reason, to support a CPCI host computer
Works like a charm, you saved my day!
Cheers, Sven
01/21/2015 12:28 PM
post113015
Hi Sven,
Awesome, glad to hear it! Thanks. :)
-Will
> Hi Will,
> Cheers, Sven
01/22/2015 3:40 AM
post113026
Hi Sven,
could you post your patched version ?
Armin Steinhoff
Fischer, Sven schrieb:
> Hi Will,
> Cheers, Sven
> http://community.qnx.com/sf/go/post113007
01/22/2015 4:57 AM
post113027
Hallo Armin,
am Donnerstag, 22. Januar 2015, 09:39:44 schrieben Sie:
it is a little bit difficult due to the fact that we are not allowed to
transfer files out of the company for security reasons. Getting the patch INTO
the company was difficult enough.
But it is fairly easy to compile: Get the BSP from
http://community.qnx.com/sf/frs/do/viewRelease/projects.bsp/frs.x86_bios.bsp_nto650_x86_bios_trunk
unpack it, go to the folder with the pci-bios-v2 source code and apply the
patch, type make and you are done.
Regards, Sven
01/16/2015 4:46 AM
post112976
Is someone able to explain why QSSL isn't able to realize a similar fix ??
It's hard to understand ...
--Armin
Will Miles schrieb:
> Hi Sven,
> -Will
> http://community.qnx.com/sf/go/post112956
01/16/2015 3:26 PM
post112981
Hi Armin,
Far be it for me to speak for QNX, but my workaround is a bit of a hack - it replicates some data structures - the bus
topology - from elsewhere in the PCI server; "doing it right" would essentially require changing some parts of the
encapsulation model in the current PCI server software architecture. Someone at QNX is actually working on a
completely new PCIe server - there's a beta up at http://community.qnx.com/sf/go/pkg2665. I haven't tested it yet, but
it might already fix this. Given both of these conditions, I can at least understand not moving quickly on it.
-Will
