Forum Topic - paddr_t: (4 Items)
paddr_t
Shouldn't paddr_t be an unsigned 64bit value instead of 32.  Or did I misunderstand the scope of its usage.
Re: paddr_t
It can be either, depending on _PADDR_BITS
Colin
> http://community.qnx.com/sf/go/post7497
cburgess@qnx.com
Re: paddr_t
This is a user config.  I'm free to set it to 32 or 64 with no danger of breaking anything, if my own code ? ;-)  I
noticed the _PADDR_BITS this in the header file but because it's prefixed with _ I assumed it was a system symbol and
should be left untouched.
_PADDR_BITS doesn't shoudl
> Colin
> > OSTech
> cburgess@qnx.com
Re: paddr_t
Just like _FILE_OFFSET_BITS controls off_t
Your code should be ready to accept 32 bit or 64 bit paddr_t - you can test
for _PADDR_BITS
if you need to change behaviour based on this.
Check proc/*/cpu.mk - some of them define _PADDR_BITS to be 64, the
corresponding defines
will be set for startup too.
> breaking anything, if my own code ? ;-)  I noticed the _PADDR_BITS this
> system symbol and should be left untouched.
>  > Colin
>  > > _______________________________________________
>  > > OSTech
>  > cburgess@qnx.com
> http://community.qnx.com/sf/go/post7499
cburgess@qnx.com
