08/28/2014 6:36 AM
post111585
Il 28/08/2014 11:38, Aarthi CR ha scritto:
> Hi All,
> I am developing SPI driver for i.Mx6 in QNX. I have used interrupt attach to attach the interrupts.
> I get one interrupt intially (i is printed as 1 continously), but i dont receive subsequent interrupts.
> I have used InterruptAttach in the following way.Please let me know if I am using it right.
Try to use a thread instead of the ISR, so You will be able to debug
your code,
maybe You do not correctly handle SPI ...
Just run a thread like this one...
void* spi_event_thread(void* p)
struct sigevent event;
int j;
int irqLev;
int irqId;
ThreadCtl( _NTO_TCTL_IO, 0 );
//Configure SPI
//Clear Rx FIFO
memset(&event, 0, (sizeof(struct sigevent)) );
event.sigev_notify= (SIGEV_INTR);
irqLev= SPI_IRQ_LEVEL;
irqId= InterruptAttachEvent( (irqLev|_NTO_INTR_CLASS_EXTERNAL ),
&event,
_NTO_INTR_FLAGS_TRK_MSK
//Enable SPI interrupts
while(1)
j= InterruptWait(0,NULL);
// Handle here SPI event... reset SPI interrupt!
InterruptUnmask(irqLev,irqId);
return(NULL);
08/28/2014 6:38 AM
post111586
is the ISR shown below the original one from your code? I'm asking because of the comment, "//Clear Interrupt status" --
is that a note to yourself about what you still need to implement, or is it just a placeholder for some code you
removed before posting it here?
In the former case (not yet implemented), it could be that your SPI controller is still waiting for you to acknowledge
the interrupt - so actually implementing that part might indeed help.
Kind regards,
Thomas
Sent: Donnerstag, 28. August 2014 11:38
To: ostech-core_os
Subject: InterruptAttach()
Hi All,
volatile int n_interrupt = 0;
int main(int argc, char *argv[])
//Initializations
if(SPIConfigure( &dev, config.phas, config.pol, config.cs - 1 ))
printf("Configuration failed!\r\n");
exit(1);
while(1)
printf("i - %d\n",GetNoOfInterrupt());
uint8_t SPIConfigure(spiHwData_adt *dev, uint8_t phase, uint8_t polarity, uint8_t ss) {
//Initialize variables
if (ThreadCtl(_NTO_TCTL_IO, 0) == -1) {
printf("ThreadCtl\r\n");
return (!EOK);
//Configure SPI
//Clear Rx FIFO
tmp = InterruptAttach( dev->irq, spi_intr, dev, sizeof(spiHwData_adt), _NTO_INTR_FLAGS_PROCESS);
if(tmp == -1)
if (errno == EAGAIN)
printf("Interrupt are in use\r\n");
}else if (errno == EFAULT)
printf("A fault occurred when the kernel tried to access the buffers provided.\r\n");
}else if (errno == EINVAL)
printf("The value of intr is not a valid interrupt number.\r\n");
}else if (errno == EPERM)
printf("The process doesn't have I/O privileges.\r\n");
}else
printf("Attached IRQ ID = %d\r\n", tmp);
return 0;
static const struct sigevent *spi_intr(void *area, int id) {
n_interrupt++;
return NULL;
int GetNoOfInterrupt(void)
return n_interrupt;
Please let me know if you need more details Thanks in advance.
OSTech
http://community.qnx.com/sf/go/post111584
