How to access serial number of USB device?
06/17/2014 4:06 PM
post110723
My application uses usbd_connect() to register callback functions with the USB stack.
When the insertion callback function is called, I would like it to read the serial number of the USB device.
The callback function is passed pointers to a struct usbd_connection and a usbd_device_instance_t,
neither of which directly gives me the serial number. So I am trying to use them to get a pointer to a
structure that does contain this information. usbd_attach() returns EBUSY, and usbd_device_lookup()
returns NULL. Is there a better way to do this?
RE: How to access serial number of USB device?
06/17/2014 4:48 PM
post110725
Probably another process has already attached to the device. If you slay that process, then does your attach work?
You can have a second connection to the stack where your connection funcs is NULL, making it 'non exclusive' which then
allows you to also attach with this second connection to get the device descriptors, to find the serial number.
From: E McKenney [mailto:community-noreply@qnx.com]
Sent: Tuesday, June 17, 2014 4:07 PM
To: ostech-core_os
Subject: How to access serial number of USB device?
OSTech
http://community.qnx.com/sf/go/post110723
Re: RE: How to access serial number of USB device?
06/17/2014 5:01 PM
post110726
I call usbd_connect() in my main function, where I register the callback functions, so funcs is not NULL there.
When either callback function is called, it is passed a pointer to a connection struct - is this the same connection
that I opened in the main function, or is it another one? If it's another one, then I don't know what arguments
were passed to it.
My main function is still running in the background, so that the callback functions will continue to be called.
Is that the reason for the EBUSY error?
Something's not making sense here - I suspect I'm missing a key piece to the puzzle.
RE: RE: How to access serial number of USB device?
06/17/2014 5:05 PM
post110727
Try, in main, calling usbd_connect() twice, the second one have funcs set to NULL, then in the insertion callback
function, instead of using the connect passed in, use the other connect that was set up where funcs was NULL.
You'll want to establish this one first, to ensure that the connection pointer is not NULL due to a race condition where
the insertion callback may run before both connections are established.
Sent: Tuesday, June 17, 2014 5:02 PM
To: ostech-core_os
Subject: Re: RE: How to access serial number of USB device?
were passed to it.
OSTech
http://community.qnx.com/sf/go/post110726
Re: RE: RE: How to access serial number of USB device?
06/17/2014 5:07 PM
post110729
Thanks, I'll try that tomorrow.
> NULL, then in the insertion callback function, instead of using the connect
> is not NULL due to a race condition where the insertion callback may run
06/18/2014 8:50 AM
post110744
Thank you, that works! I had seen that strategy used in devc-serusb but didn't
understand why until now.
One remaining question: the iSerialNumber field is a _Uint8t not a string.
How does one get from this value to the actual serial number on the device?
RE: RE: RE: How to access serial number of USB device?
06/18/2014 8:52 AM
post110746
Good to hear.
Try this:
char *dup_usbd_string (struct usbd_device *device, uint8_t index, int langid)
char *s = usbd_string(device, index, langid);
if (s) {
s = strdup(s);
return s;
where langid is probably 0
You should be able to get the string using 'usbd_string' providing iSerialNumber as the index.
Sent: Wednesday, June 18, 2014 8:50 AM
To: ostech-core_os
Subject: Re: RE: RE: How to access serial number of USB device?
OSTech
http://community.qnx.com/sf/go/post110744
Re: How to access serial number of USB device?
06/18/2014 9:16 AM
post110748
That's perfect, thank you very much. (Same trick should also get me the manufacturer and product strings.)
The online docs are good for overall USB driver development, but they didn't happen to mention this bit. :)
06/18/2014 9:29 AM
post110750
Glad it was helpful to you.
On how we can improve our docs: specifically the trick to use a second connection for the non-exclusive attach, or
getting from iSerial, iProduct, etc., to the actual string, or both techniques?
Feel free if you'd like more help with USB for a general nature to post to the OS Meta forum:
http://community.qnx.com/sf/discussion/do/listTopics/projects.core_os/discussion.metawiki
If you have questions USB hardware drivers specific to your BSP, you can use the BSP forum:
http://community.qnx.com/sf/discussion/do/listTopics/projects.bsp/discussion.bsp
06/18/2014 9:45 AM
post110751
> connection for the non-exclusive attach, or getting from iSerial, iProduct,
Both, I guess.
The docs already cover using NULL to get a R/O connection, but doesn't really explain why you might need it. A brief
note to this effect in the context of writing callback functions would be sufficient.
And it would be good to mention usbd_string() on the page for usbd_device_descriptor(), since that's where the struct
contents are spelled out.
Overall I have to say the online docs are very good. They sometimes miss subtle bits as noted here, but what exists is
generally quite clear and sometimes even fun to read.
06/17/2014 5:06 PM
post110728
A little more explanation of what I'm doing:
I don't actually need to attach to the device, I'm just using the callback functions to capture insertion
and removal events so that I can perform other actions related to the device (such as starting a driver).
So when I call usbd_connect() I need to pass in the callback functions, but that gives me a R/W connection which I don't
really need for my purposes. Unless I actually have to attach to each device in order to read more information than is
provided in the instance struct.
