Forum Topic - IMX6 freescale Sabre lite Board getting heated up :
Hello All
Iam using Imx6 freescale sabrelite board load BSP provided by QNX "BSP_freescale-imx6q-sabrelite_br-650_be-
650sp1_SVN718398_JBN28.zip" on to the board.
The board is generating lot of heat even a 3 minitues up and running of QNX os will generate too much of heat. Can
anyone please give me solution to reduce the amount of heat been geneated by the board.
This heat happen only when QNX OS is up and running.
Regards
Kaushik
Re: IMX6 freescale Sabre lite Board getting heated up
Please download the latest Sabre-Lite BSP which should resolve heat issues. There was an issue where the audio codec was
 heating up which was fixed.
I am also facing same issue. Please help us solve this ASAP.
Rahman
Which BSP are you using?
Mark Wakim
Embedded Software Developer, QNX Software Systems Limited
613-591-0836 x24683 <tel:613-591-0836%20x24683>
>Regards,
>Rahman
>OSTech
>http://community.qnx.com/sf/go/post111758
>ostech-core_os-unsubscribe@community.qnx.com
Hi Mark,
I tried with both 6.5 and 6.6.
Using the latest BSP on F27, E.g. for 6.5.0 SP1
"BSP_freescale-imx6q-sabrelite_br-650_be-650sp1_SVN737078_JBN59.zip”?
Also you can enable DVFS to reduce temperature, make sure to use the "-w”
option if using 6.5.0 SP1 without the updated kernel patch. DVFS can also
display the core temperature at runtime. Also you can add a heatsink like
Freescale does with their SABRE ARD Quad reference boards.
Mark Wakim
On 2014-09-17, 8:55 AM, "Abdur Rahman" <community-noreply@qnx.com> wrote:
>Hi Mark,
>OSTech
>http://community.qnx.com/sf/go/post111760
Hi Mark,
Greetings!!
I am using "BSP_freescale-imx6q-sabrelite_br-650_be-650sp1_SVN737078_JBN59.zip" which you had mentioned.
I will enable DVFS and update the result.
Rahman
Hi Mark,
I have enabled DVFS and following are the output.
# cat /dev/dvfs_client_1
Core Temp = 46
Power Level = 4
Mode = Auto (0)
CPU0 Load = 0
CPU1 Load = 0
CPU2 Load = 0
CPU3 Load = 0
# cat /dev/dvfs
   Core Temp = 44
   Mode = Auto (0)
  #  |  App  |  Thermal
  0  |   -  |     -
  1  |   -  |     -
  2  |   -  |     -
  3  |   -  |     -
 *4  |   -  |     -
Hi Mark,
Core temperature decreased from 56 to 47 C after enabling the DVFS. It improved bit.
Is there anything else we can do to reduce it more?
Rahman
Please make sure using DVFS all the IO are functioning fine we used DVFS to
reduce temperature but unfortunately SDIO card was not functioning.
Please verify the same.
Regards
Kaushik
On Wed, Sep 17, 2014 at 9:37 PM, Abdur Rahman <community-noreply@qnx.com>
wrote:
> Hi Mark,
> improved bit.
> http://community.qnx.com/sf/go/post111768
Attachment: HTML sf-attachment-mime26693 1.28 KB
I have the same problem on SabreSD SсC IMX6q and bsp
BSP_freescale-imx6q-sabresmart_br-660_be-660_SVN850002_JBN1126.zip
BSP_freescale-imx6q-sabresmart_br-660_be-660_PATCHES_JBN1126.zip
setting up DVFS does not solve the problem
