Forum Topic - iofunc_open_default - passing void* as argument in C++: (2 Items)
Hello people!
This is my first post, and am excited about participating in the QNX community.
I'm attempting to write a resource manager in C++, and I was given a mickey-mouse example program so I could learn how
to write one. In this program, I have an io_open() function that will be called every time an open() request comes in.
Here is the code for the function:
int io_open( resmgr_context_t *ctp, io_open_t *msg,
 RESMGR_HANDLE_T *handle, void *extra )
    int returnVal = 0;
    printf("Some debug message\n")
    returnVal = iofunc_open_default( ctp, msg, handle, extra );
    return ( returnVal );
The prototype for iofunc_open_default() is as follows (in sys/iofunc.h):
int iofunc_open_default( resmgr_context_t *ctp, io_open_t *msg,
 iofunc_attr_t *attr, void *extra );
When I attempt to compile, I get the following error message in reference to the 'void *extra' parameter argument:
"ANSI C++ forbids implicit conversion from `void *' in argument passing"
So my question is, do I need to explicitly compile my resource manager in C? Or is there a way I can pass in (void *) to
 the iofunc_open_default() in C++? It seems to me there should be a way, otherwise C++ should also complain that there
is a (void *) parameter in the argument list.
If this is the wrong forum, I ask for mercy and to be redirected to the proper forum.
Thanks!
~Anthony
Re: iofunc_open_default - passing void* as argument in C++
How are you compiling ( flags ).  I'm getting a diifferent error then you.  RESMGR_HANDLE_t is by default equal to (void
*).  Thus handle will generate the warning and must be cast to  (iofunc_attr_t*)
> Hello people!
> mouse example program so I could learn how to write one. In this program, I
> comes in. Here is the code for the function:
>     int returnVal = 0;
> Or is there a way I can pass in (void *) to the iofunc_open_default() in C++?
> there is a (void *) parameter in the argument list.
>  forum.
> Thanks!
> ~Anthony
