Forum Topic - ARM11 D-cache: (2 Items)
ARM11 D-cache
In looking at _start.S from omap2420 bsp, I see that level one I-cache is enabled but D-cache is disabled.
Does D-cache ever get enabled?  Or is there some reason it is left disabled?
Re: ARM11 D-cache
The dcache is enabled when the MMU is enabled before jumping to the kernel.
See the vstart function in startup/lib/cstart.S.
The IPL and startup execute with the MMU disabled and the dcache behaviour
when the MMU is disabled is typically cpu-dependent, so it would require
potentially cpu-dependent code to be used at the points in startup where
the dcache needs to be cleaned/flushed.
For the icache, it's always safe to invalidate it when the MMU is enabled
which can be done with a cpu-independent operation.
	Sunil.
> disabled?
> http://community.qnx.com/sf/go/post7042
