Forum Topic - Interrupt management on Beaglebone running QNX 6.5: (10 Items)
Hi guys,
I'm tryingot fogire out how can I use interrupts on my Beaglebone running QNX 6.5.
My need is to use GPIO1_12 as interrupt line when a user push down a botton.
In order to do so I've setup the GPIO1_12 in pullup mode in order to detect, thorough falling detect condiction when the
 user press the button.
Based on my researches, I've written the following code, it compiles but it doesn't work:
Do you have some suggetions?
Thanks guys.
################################ CODE #########################################
#include <cstdlib>
#include <iostream>
#include <sys/mman.h>
#include <pthread.h>
#include <sys/neutrino.h>
#include <errno.h>
#include <stdint.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <stdint.h>
#include <hw/inout.h>
#include <am335x.h>
#include <stdio.h>
#define AM335X_CTRL_BASE	        0x44E10000
#define conf_gpmc_ad12		0x0830 // (AM335X_CTRL_BASE+0x0830)
#define SLEWCTRL			        (0x1 << 6)
#define	RXACTIVE			(0x1 << 5)
#define	PULLUP_EN			(0x1 << 4) /* Pull UP Selection */
#define PULLUDEN			(0x0 << 3) /* Pull up enabled */
#define PULLUDDIS			(0x1 << 3) /* Pull up disabled */
#define MODE(val)			val
#define GPIO_OE 			0x134
#define AM335X_GPIO_SIZE	0x00001000
#define AM335X_GPIO1_BASE   0x4804C000
#define GPIO1_IRQ 99
int init_gpio1_12(void);
const struct sigevent * isr_handler (void *arg, int id);
void * int_thread (void *arg);
struct sigevent event;
uintptr_t ptr;
uintptr_t ptr2;
int count;
int error;
	init_gpio1_12();
	event.sigev_notify = SIGEV_INTR;
	printf("Creating interrupt thread…\n");
	pthread_create (NULL, NULL, int_thread, NULL);
	delay(5);
	while(!error) {
	printf("count=%i\n", count);
	fflush(stdout);
	sleep(1);
    return EXIT_SUCCESS;
int init_gpio1_12()
	int pad;
   	ThreadCtl(_NTO_TCTL_IO, 0);
        // The register that I want to use as gpio (conf_gpmc_ad12) is located at the address 0x0830, so I will map the
memory from AM335X_CTRL_BASE addresss to AM335X_CTRL_BASE+0x0840
   	ptr = (uintptr_t)mmap_device_memory(0, AM335X_CTRL_BASE+0x0840, PROT_READ|PROT_WRITE|PROT_NOCACHE, 0,
AM335X_CTRL_BASE);
	if ( ptr == MAP_DEVICE_FAILED ) {
		perror( "mmap_device_memory for physical address failed");
		return -1;
	pad = in32(ptr + conf_gpmc_ad12) & 0x0000ffff;
        // I set conf_gpmc_ad12 in MODE 7 to enable the pin as GPIO1_12
	out32(ptr + conf_gpmc_ad12, MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE | SLEWCTRL);
	//pad = in32(ptr + conf_gpmc_ad12);
   	ptr2 = (uintptr_t) mmap_device_memory(0, AM335X_GPIO_SIZE, PROT_READ|PROT_WRITE|PROT_NOCACHE, 0, AM335X_GPIO1_BASE);
	if ( ptr2 == MAP_DEVICE_FAILED ) {
		return -1;
	out32(ptr2 + GPIO_OE,(1 << 12));
	out32(ptr2 + GPIO_FALLINGDETECT, (1 << 12));
	return (&event);
	// enable I/O privilege
	ThreadCtl (_NTO_TCTL_IO, 0);
	// attach the ISR to IRQ
	if (InterruptAttach (GPIO1_IRQ, isr_handler, NULL, 0, _NTO_INTR_FLAGS_TRK_MSK) == -1)
		error = 1;
	while (1)
		InterruptWait (NULL, NULL);
		count++;
Re: Interrupt management on Beaglebone running QNX 6.5
Hi!
What does it mean:
> Hi!
> What does it mean:
out32 is a function that takes two inputs:
out32(addr,value)
The parameters are
1) address where to write
2) value to write
So :
ptr2 + GPIO_OE is the address.
(1 << 12) is the value: 1 << 12 means: shift value 1 of 12 position to left
More infomation can be found on the processor TRM.
Thanks, but i know what does this function do. But as are u sure that GPIO_OE (0x134) is correct value. If yes, what
does it refer to?
And if u have solved this problem, can u say how? because im also trying to configure interrupt from PIN filling edge,
but handler doesnt calls anymore.
Hi, I found that value in the TRM document for AM335X.
You can find it at http://www.ti.com/lit/ug/spruh73i/spruh73i.pdf
Page 4656
Actually I put this project in stand-by. If you have any update please, let me know.
Hi! I have solve my problem and now i'm getting interrupts. But i don't know what i exactly have edited in my code. So,
i can simply send u my working source!
Yes, Thanks!
My email is alessandro [dot] nuke [@] gmail [dot] com
My email is: alessandro.nuke@gmail.com.
Thanks for sharing your code!
Alessandro
It is working code:
#include <stdlib.h>
#include <stdio.h>
#include <stdint.h>
#include <unistd.h>
#include <arm/mx6x.h>
#include <arm/mx6x_iomux.h>
#include <arm/inout.h>
#include <errno.h>
#define GPIO_PAD_OUTPUT ( PAD_CTL_PUS_100K_PU | PAD_CTL_ODE_DISABLE | PAD_CTL_SPEED_LOW | PAD_CTL_DSE_240_OHM  |
PAD_CTL_SRE_SLOW )
#define GPIO_PAD_INPUT ( PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_PUS_22K_PU | PAD_CTL_SPEED_LOW | \
                            PAD_CTL_DSE_80_OHM | PAD_CTL_HYS_ENABLE)
#define IRQ_GPIO7_13	365
#define MY_PIN			13
static uint32_t count = 0;
static uint32_t count_last;
static const struct sigevent *spi_intr(void *area, int id);
	printf("0\n");
	if (ThreadCtl(_NTO_TCTL_IO, 0) == -1) {
		printf("ThreadCtl\r\n");
		return (!EOK);
	uintptr_t gpiobase;
	int result = InterruptAttach( IRQ_GPIO7_13, spi_intr, &gpiobase, sizeof(&gpiobase), _NTO_INTR_FLAGS_PROCESS);
	if(result == -1)
		if (errno == EAGAIN)
			printf("Interrupt are in use\r\n");
		}else if (errno == EFAULT)
			printf("A fault occurred when the kernel tried to access the buffers provided.\r\n");
		}else if (errno == EINVAL)
			printf("The value of intr is not a valid interrupt number.\r\n");
		}else if (errno == EPERM)
			printf("The process doesn't have I/O privileges.\r\n");
		}else{
			printf("WTF.\r\n");
	}else
		printf("Attached IRQ ID = %d\r\n", result);
	// pin configuration ...
	gpiobase	= mmap_device_io( MX6X_GPIO_SIZE,	MX6X_GPIO7_BASE );
	uintptr_t iomuxbase	= mmap_device_io( MX6X_IOMUXC_SIZE,	MX6X_IOMUXC_BASE );
	// set Logic ONE to Pin #5
	out32( gpiobase + MX6X_GPIO_DR, in32(gpiobase + MX6X_GPIO_DR) | (1 << MY_PIN) );
	// set INPUT direction for Pin #5
	out32( gpiobase + MX6X_GPIO_GDIR, in32(gpiobase + MX6X_GPIO_GDIR) & ~(1 << MY_PIN) );
	// ... pin configuration
	// set Interrupt CONFIGURATION "Rising Enge" for Pin #5 (ICR1: 0-15), two bits per pin
	out32( gpiobase + MX6X_GPIO_ICR1, (in32(gpiobase + MX6X_GPIO_ICR1) & ~(0x11 << (MY_PIN*2))) | (0x11 << (MY_PIN*2)) );
	// clear Disregarding "Rising Enge" for Pin #5
	out32( gpiobase + MX6X_GPIO_EDR, in32(gpiobase + MX6X_GPIO_EDR) | (1 << MY_PIN) );
//	printf("IRQ registers has been configured :)\n");
	// set Interrupt ENABLED for Pin #5
	out32( gpiobase + MX6X_GPIO_IMR, in32(gpiobase + MX6X_GPIO_IMR) | (1 << MY_PIN) );
	out32( gpiobase + MX6X_GPIO_ISR, in32(gpiobase + MX6X_GPIO_ISR) | (1 << MY_PIN) );
	out32( iomuxbase + MX6X_IOMUX_SWMUX + (4 * SWMUX_GPIO_18), MUX_CTL_MUX_MODE_ALT5);
	out32( iomuxbase + MX6X_IOMUX_SWPAD + (4 * SWPAD_GPIO_18), GPIO_PAD_INPUT);
	InterruptEnable();
	while(1)
#if 0
		if ( !(in32(gpiobase + MX6X_GPIO_PSR) & (1 << MY_PIN)) )
			spi_intr(NULL, 0);
		#endif
		out32( gpiobase + MX6X_GPIO_IMR, in32(gpiobase + MX6X_GPIO_IMR) & ~(1 << MY_PIN) );
		if(count != count_last)
			count_last = count;
			printf("\tPRESSED - %u times\n", count);
		delay(10);
	count++;
	return NULL;
